RE: Vailly FW 190 Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Vailly FW 190 Build
Page: <<   < prev  10 11 [12] 13 14 15 16 17 18 19   next >   >>
Login
RE: Vailly FW 190 Build - 2/1/2008 10:08:18 PM
Ironmanx43
Status: offline
Update: I have now finished the Functioning Parts to the Functional Canopy. The followinng Pics tell the story
Correction to the 2nd Picture. It was 3/32nd Bass Wood, Not 1/16.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Ironmanx43 -- 2/2/2008 2:08:11 AM >
_____________________________
Andrew
(in reply to Ironmanx43)
       Post #: 276
RE: Vailly FW 190 Build - 2/1/2008 10:11:37 PM
Ironmanx43
Status: offline
The Rest of the Story.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Andrew
       Post #: 277
RE: Vailly FW 190 Build - 2/1/2008 10:18:33 PM
Ironmanx43
Status: offline
Ok Now if you'd like to see the canopy in action: http://www.rcuvideos.com/item/MJVGKQFF1GRM8DMT
I need to do some minor adjustments, but its in.
My Next Step is to Mount the Engine and Throttle Servo
< Message edited by Ironmanx43 -- 2/1/2008 10:19:27 PM >
Andrew
       Post #: 278
RE: Vailly FW 190 Build - 2/3/2008 2:18:27 AM
Ironmanx43
Status: offline
The engine is mounted and the pictures follow, but I can use some help. You will notice in the second to last picture that I am dry mounting the cowl. It does not fit. Has anyone run into this problem before and what did you do to fix it. Any others that can give me some suggestions, please chime in.
THe problem is not the engine but rather it seems to do more with the diameter of the cowl itself.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Ironmanx43 -- 2/3/2008 2:22:40 AM >
Andrew
       Post #: 279
RE: Vailly FW 190 Build - 2/3/2008 2:21:11 AM
Ironmanx43
Status: offline
Here are the last 3 pics. The one in the middle shows the cowl clearance problem.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Ironmanx43 -- 2/3/2008 2:22:04 AM >
Andrew
       Post #: 280
RE: Vailly FW 190 Build - 2/3/2008 9:40:50 PM
AFARACI
Status: offline
http://www.scaleaircrewsupplies.co.uk/raf_pilot.htm
andrew
looks good so far...
seems like some adjustments are in order ...gunhood ,bulkhead,cowl etc.
attached is a site from the uk that u might find interesting
watch the videos ....amazing! i see pilot movements linked to aircraft surfaces...
happy superbowl sunday...go giants!
       Post #: 281
RE: Vailly FW 190 Build - 2/3/2008 9:42:28 PM
AFARACI
Status: offline
how scale can one get? seems as if possiblities are endless..............
(in reply to AFARACI)
       Post #: 282
RE: Vailly FW 190 Build - 2/4/2008 3:10:29 AM
Ironmanx43
Status: offline
Art - Yes the scale possibilities are endless. Regarding today's game , I don't even know whos winning right now. I like both the patriots and giants so no matter who wins, so do I.
Tody I have finished the throttle and the 2 x air servos for the canopy and retracts. Next I'll run the air hoses to them and then probalby start on the cockpit as I need to get that doe before glassing. ALso, I fixed the cowl issue by sanding the upper sides of Former 1. It now fits just fine. Here are the pics.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Andrew
       Post #: 283
RE: Vailly FW 190 Build - 2/5/2008 12:57:01 AM
Ironmanx43
Status: offline
Not a great deal of progress today. But I've managed to install the tank leaving to do the plumbing and added muffler extensions where I want them. The exhaust shall be below the fuse.
Click for fullsize
Click for fullsize
Click for fullsize
Andrew
       Post #: 284
RE: Vailly FW 190 Build - 2/5/2008 1:35:27 AM
AFARACI
Status: offline
andrew
your really coming along now.very nice work
how do you plan on finishing the exhaust ? did you build any right thrust into the firewall? do you plan on glassing the model?
on that subject youre right glassing my spitfire would be hazrdous to its health awhile back i built a 60 size aircobra
and needless to say thats no longer with us..... i truly enjoy this thread and keep it up doin great
       Post #: 285
RE: Vailly FW 190 Build - 2/5/2008 2:02:16 AM
Ironmanx43
Status: offline
quote:
ORIGINAL: AFARACI
andrew
Art - The exhaust is now done as in the pic. That's how ROy Vaillancourt said to do it, so I'm going to stick with it the way I now have it. Also, Roy said no right thrust into the engine: zero degrees on the firewall. If there is a problem, then I'll correct for it after the maiden flight -- all going well LOL. Yes, I will be glassing her with some .5 oz cloth then paint.
RIght now I am trying to decide how I want to disable the steering servo for when the retracts are up. I have an idea but am too tired to put it in tonight. Maybe tomorrow after I take a trip to the local hobby shop and pick up some large dia. tygon to finish up the tank.
Hope you enjoyed yesterday's game. I heard it was a good one.
Andrew
       Post #: 286
RE: Vailly FW 190 Build - 2/5/2008 2:41:49 AM
AFARACI
Status: offline
andrew
thoughts on dissable tailwheel servo when retracts up....
isnt that somthing u might be able to do with a computer radio?
or program to a freely assigned function switch? i dunno just a thought
dont know what radio your using....
for instance: linked to rudder when retract servo position down
un linked and not used when retract servo in valve up position
just a thought ...also seen another fellow use springs on tailwheel cables on servo end...when tailwheel up cables sloppy and no movement
just throwin ideas at ya i confused myself
