RE: Vailly FW 190 Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Vailly FW 190 Build
Page: <<   < prev  13 14 15 16 17 [18] 19 20 21 22   next >   >>
Login
RE: Vailly FW 190 Build - 5/13/2008 11:31:20 PM
wulf190
Status: offline
Various thicknesses of plastic has done well for me too on those things Andrew. I've done Flitemetal on a lot of areas as well, but the variety of thicknesses to the plastic panels seems to set things off nicely under the paint. It sure is a lot easier than trying to tape of smooth edged corners w/ 1/64 chartpack tape I've found. I've ended up with a whole set of little templates for those parts for the 1/5 190. In fact, I've been using the plastic punch outs from a hole punch in a styrene sheet for the larger raised rivets on the wing fillets. Burning in a rivet circle into the styrene circle makes a fairly decent looking part for those..and without the dimpling effect that can occur w/ the glue rivets.
(in reply to Ironmanx43)
       Post #: 426
RE: Vailly FW 190 Build - 5/14/2008 3:08:29 AM
Ironmanx43
Status: offline
yup, using the plastic sure makes it easier. Meanwhile, the bottom wing rivets are almost done. I'm using a dremel, a metal template and a brass tube to lightly drill the rivets. ITs working pretty well. not perfect, but for a first timer it will do. More pics to come soon.
< Message edited by Ironmanx43 -- 5/14/2008 3:10:01 AM >
_____________________________
Andrew
(in reply to wulf190)
       Post #: 427
RE: Vailly FW 190 Build - 5/15/2008 12:58:21 AM
Ironmanx43
Status: offline
Still adding more rivots, here's a pic from the wing:
Click to see fullsize image.
Click for fullsize
Andrew
       Post #: 428
RE: Vailly FW 190 Build - 5/16/2008 1:38:10 AM
Ironmanx43
Status: offline
Still adding yet even more rivets.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Andrew
       Post #: 429
RE: Vailly FW 190 Build - 5/16/2008 10:06:48 AM
LDM
Status: offline
Nice job , first class work on those rivots
LDM
       Post #: 430
RE: Vailly FW 190 Build - 5/16/2008 4:14:57 PM
BobH
Status: offline
Isn't there supposed to be a hinge along that line on both sides? Adding a piano hinge might just do the trick..
BobH.
(in reply to AFARACI)
       Post #: 431
RE: Vailly FW 190 Build - 5/17/2008 11:26:28 AM
Ironmanx43
Status: offline
quote:
ORIGINAL: BobH
Bob - can you get more specific, there's a lot of lines here.
Andrew
(in reply to BobH)
       Post #: 432
RE: Vailly FW 190 Build - 5/21/2008 12:44:21 AM
Ironmanx43
Status: offline
Started to do some painting. Here are the pics of the flaps, servo covers and retract covers. Although some of the pics look like I am painting grey, it is not. (Bad lighting) Look at the servo cover in the wing pic. Its actually a sky blue. The Blue paint is from OMNI (just like PPG auto paint). THe red (inside flaps is Model Masters. After spraying the base color I hit it with a heavy coat of clear which is like an epoxy.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Ironmanx43 -- 5/21/2008 12:47:12 AM >
Andrew
       Post #: 433
RE: Vailly FW 190 Build - 5/21/2008 12:46:14 AM
Ironmanx43
Status: offline
More pics regarding last post
Click for fullsize
Click for fullsize
Click for fullsize
Andrew
       Post #: 434
RE: Vailly FW 190 Build - 5/21/2008 3:07:31 AM
Ironmanx43
Status: offline
Pics after clear coat
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Andrew
       Post #: 435
RE: Vailly FW 190 Build - 5/21/2008 3:27:33 AM
t_burley
Status: offline
curious as to what the red in the flap area is for?
keep up the riveting work. there sure are alot
of rivets on a 190
< Message edited by t_burley -- 5/21/2008 3:28:17 AM >
Todd
Meister, Aero Acc., Sierra, Glennis, Get Stencils, Shinden, Warbird Colors, Fliteskin customer
       Post #: 436
RE: Vailly FW 190 Build - 5/21/2008 12:03:51 PM
Ironmanx43
Status: offline
quote:
ORIGINAL: t_burley
of rivets on a 190
Its not scale, but It sure will look good when the flaps are down on a fly by
Andrew
(in reply to t_burley)
       Post #: 437
RE: Vailly FW 190 Build - 5/21/2008 3:48:34 PM
BobH
Status: offline
Here's where the piano hinge is on both sides of the cowl.
Red flaps.. gasp!
Click for fullsize
BobH.
