Ironmanx43
OK, USA Status: offline
quote:
ORIGINAL: Redwulf__34 What kind of paint are you using? I've never used Frisket, but I've thought about it. Like Bob said you have to seal the edges. On my last model I used clear dope to seal all the tape edges. Some of the underlying color would be a better idea depending on what kind of paint your using. Sean Well for the emblems I am using Model Master Acryllic. I could not afford the good paint (ppg) for them. However, the final coat will be PPG clear which is an epoxy. I understand about sealing the ends. However, I am going to go with masking tape for the rest of the emblems. I think it will be easier.
_____________________________
Andrew
