RE: Vailly FW 190 Build
Tower Hobbies
Logged in as Guest
  Printable Version
Ziroli Stuka - laser lizard cut short kit - Kit
Seller:  laserlizard
Details:   $99.98   |  7/18/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Vailly FW 190 Build
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Vailly FW 190 Build - 11/15/2007 12:45:21 AM
Ironmanx43
Status: offline
Thanks Dave for your input. Hope everything is well down under (sorry couldn't resist)
_____________________________
Andrew
(in reply to ticketec)
       Post #: 26
RE: Vailly FW 190 Build - 11/15/2007 12:46:58 AM
Ironmanx43
Status: offline
Dave - P.S. I've heard that the F/G Fuse will increase your weight. If it was me (and it is at least here) I'd go with balsa and forget the F/G.
Andrew
(in reply to Ironmanx43)
       Post #: 27
RE: Vailly FW 190 Build - 11/15/2007 3:35:32 PM
larry@coyotenet
Status: offline
I am currently building the vailly 190 from a Precision kit. Here are my observations.
The plans and the kit are both off slightly on every piece. Variations are from 1/8 to 1/2 inches in some parts. The wood was overall acceptable but some of the parts and sheeting were horrible. Wing ribs required enlarging the notches for the spars and recutting the notches by 1/16th to 1/8 on every rib. All wood was labeled and easy to recognize. Some of the wood appears to be either old or very dry. It actually shattered when bent. Light ply parts were generally good but some of the ribs were warped badly. The method for building the wing was easy and went together fast except for the need to fine tune every part before it would fit correctly. The method of building the wing in the flap area required much beefing up since it had no spars and depended on 3/32 sheeting and ribs for it's structure, warped quite easily. The flaps themselves warp easily unless beefed up. I am no fan of the way the surfaces built, they look really good when done but the method of construction with the 1/32 ply forming the trailing edges is not my favorite. I was forced to get a plastic model of the 190 in order to visualize the contours of the fuselage for sheeting, the plans are very vague in this area. I am using Gene Barton retracts which are works of art but which have the worst mounting system I have ever seen, They required a very unique mount to be built into the wing.
I would go with the Vailly or the Robart retracts next time, very simple to mount.
Overall impression, Either the plans shrink and expand due to humidity (can be a problem with blueprint type plans) or they don't match the kit. Nothing is off very much but nothing really fits exactly. I would use a glass fuse next time, the shape of the 190 is deceiving unless you have a plastic model to go from, This probably is the reason why so many models of the 190 don't look quite right and you don't know why. The structure of the plane is quite light, for instance, the wing is 92" and a large chord, yet the spars are two (2) 1/4 x 1/2 spruce or basswood with 1/16 shear web. Wing center section braces are 1/8 ply and rear spar is 1/4 x 1/2 balsa on the bottom and 1/4 x 1/8 spruce on the top. The one I am working on will have the center section wrapped for strength. Fiberglass cowl is great, but BIG. I would say that this plane has a lot of air built into it! Should be able to meet the weight suggestion of 28 to 32 pounds with no problem, only trouble might be the retracts which weigh quite a bit more than the ones the plans show.
This plane is not for the novice, or even the reasonably good builder. I can see someone with experience building, say the TopFlite giant scale kits being totally lost on this one. For comparison my experience building warbirds and sport planes goes back to the early 70's building just about every TF and Royal scale kit and advancing to scratch building from my own plans and building from Bryan Taylor and other English plane designers. I have probably built close to 100 various types of planes from kits and plans and scratch so I consider myself to be competent builder.
Would I build this plane again? Yes. I would change some things like getting a glass fuse and using Vailly retracts, but I am sure the finished plane will be a great flier and look impressive.
Larry
(in reply to bps)
       Post #: 28
RE: Vailly FW 190 Build - 11/15/2007 4:09:16 PM
Ironmanx43
Status: offline
WOW - I am becoming very disillusioned. So many negative vibes regarding PCK, its putting my engineering background into a flatspin. I'll try to take the negatives, put them in a box and remember that I helped design upgrades to both the Patriot and AMRAAM missles when I worked at Raytheon and see where it takes me. Wish me luck and many happy thoughts.
Andrew
(in reply to larry@coyotenet)
       Post #: 29
RE: Vailly FW 190 Build - 11/15/2007 8:41:15 PM
Ironmanx43
Status: offline
THought I'd let you all in on the paint scheme I am thinking of attempting. Here it is. However, I am open to suggestions for others.
Click to see fullsize image.
Click for fullsize
Andrew
       Post #: 30
RE: Vailly FW 190 Build - 11/15/2007 10:14:57 PM
larry@coyotenet
Status: offline
Not a knock on Precision Cut Kits, just my observations on the kit I am building. I think the problem, differences between kit and plan, might be caused by differences in the plans used to cut the kit and the plans I was sent. I still think it could be the plan shrinking and expanding due to temp or humidity. I live in a very low humidity location while Vailly is in a high humidity area. It is possible that the parts also changed because of the differences between the humidity. I do think that the wood included with the kit for sheeting the wing was very uneven in quality, even to the point of changing from hard to soft on the same sheet. Would I build another PCK cut kit? Certainly, but nothing is perfect. Sorry to keep changing this post but forgot to mention that plane will use either a Quadra 100 or a Brison 5.8. We fly at 5,000 feet so the extra power comes in handy.
Larry
< Message edited by larry@coyotenet -- 11/15/2007 10:32:51 PM >
       Post #: 31
RE: Vailly FW 190 Build - 11/15/2007 10:38:53 PM
Ironmanx43
Status: offline
No problem, Larry. Just receiving bad vibes from people regarding a kit I just put doen my money on. Do you have any pics of your FW190? I'd love to see them.
Andrew
       Post #: 32
RE: Vailly FW 190 Build - 11/16/2007 7:12:03 PM
Ironmanx43
Status: offline
Update - the goodies from Vailly have just arrived - I am preparing to sling balsa and hopefully provide som pics tonight
Andrew
       Post #: 33
RE: Vailly FW 190 Build - 11/17/2007 12:54:24 AM
Ironmanx43
Status: offline
Ok got to give credit where credit is due. Larry was abosolutely right. Although the laser cut ply parts seem to be on the mark, there are a number of Balsa parts that are 1/16 to 1/8 off the mark, just like Larry said. Also, the full kit was missing some balso stock and balsa filler stock. I'm not miffed, but I am not pleased.
Nevertheless, with a good heart I proceed anyway. I've started on the rudder. I'll have to go to my LHS to get some filler stock to finish it. Here are some Pics of the goodies I got from Vailly today and the beginning of the Rudder.
Andrew
       Post #: 34
RE: Vailly FW 190 Build - 11/17/2007 12:57:39 AM
Ironmanx43
Status: offline
Goodies
Andrew
       Post #: 35
RE: Vailly FW 190 Build - 11/17/2007 1:00:28 AM
Ironmanx43
Status: offline
Problems uploading -- Please standby
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Andrew
       Post #: 36
RE: Vailly FW 190 Build - 11/17/2007 1:03:07 AM
Ironmanx43
Status: offline
More Goodies
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Andrew
       Post #: 37
RE: Vailly FW 190 Build - 11/17/2007 1:06:47 AM
Ironmanx43
Status: offline
Some More Goodies
