RE: A NEW PATRIOT IS BORN!!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: A NEW PATRIOT IS BORN!!! Page: <<   < prev  1 2 3 [4]
Login
RE: A NEW PATRIOT IS BORN!!! - 2/8/2008 5:42:40 PM
bob27s
Status: offline
quote:
ORIGINAL: Mark 5
Hello,bob27s,I have to agree with you.The YS60 is one of the strongest 60's out there.They are also very dependable,too bad this engine is no longer available. Razor-RCU,do you really think that a jett50 has more power than a YS 60?You have got to be kidding! The jett50 is one great engine,but more power than a YS60, I dont think so.Unless you sprinkle a little pixie dust on jett 50,then it would be more powerfull than the OS90DF.
Razor is not all that far off base... but making a statement like that either way would require some qualification.
The SJ50 and SJ60L are quite powerful. The SJ-60LX even more so.
Replace the standard jett-stream muffler with a full size pipe, and there is more to be had.
(In fact, the SJ-60L and SJ-60LX have gained some favor with the SPA and BPA pattern organizations - replacing in some aircraft what were in the historical aircraft OS-FSR, Rossi, Webra and YS .61 engines. )
The engines are designed for different applications, and different RPM ranges.
If you went just by HP numbers calculated on a calibrated dyno, the SJ50 and YS60 engines might look pretty much equal.
But when you look at the rpm curve and where the HP is developed at, you see the divergence in application.
For speed, a smaller diameter prop is prefered, spinning at higher rpm (generalized). The SJ50 or SJ60 engines are better suited for that than the YS60 is. Keeping that prop disk area to a mimimum is a significant drag-reduction.
_____________________________
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to Mark 5)
       Post #: 76
RE: A NEW PATRIOT IS BORN!!! - 2/10/2008 12:38:47 AM
Mark 5
Status: offline
bob 27s, I have to agree with you,a small light 40 size patriot with a jett 60LX is probably the ideal combo.and this is what I would have used if I did not have my YS60.The preformance of my patriot with this engine is very good for a prop. powered airplane.I am getting similar speed spinning a 12 pitch prop. at 13,000 as my friend would in his patriot spinning an 8 pitch prop. at 18,000.I guess that prop. selection is just as important as the engine and airplane.You probably know more about this than all of us.Back to work on my next speed plane,it will be much faster than my patriot.
(in reply to bob27s)
       Post #: 77
RE: A NEW PATRIOT IS BORN!!! - 2/10/2008 1:32:09 AM
funflyerf4
Status: online
Hey Mark your days are numbered buddy,The new Patroit on the field is just about done.Can you say 200+ all right just wishing.
       Post #: 78
RE: A NEW PATRIOT IS BORN!!! - 2/10/2008 2:22:19 AM
Mark 5
Status: offline
Hello Frank, your patriot should be very fast,it should be faster than mine. Ihope you dont rip the covering off with those high speed low inverted passes of yours.
(in reply to funflyerf4)
       Post #: 79
RE: A NEW PATRIOT IS BORN!!! - 2/13/2008 3:21:32 AM
Mark 5
Status: offline
Hello Frank, what's the storys. Is the race still on.
       Post #: 80
RE: A NEW PATRIOT IS BORN!!! - 9/4/2008 5:47:33 PM
särpet
Status: offline
PATRIOT XL
engine webra .90P5 apc 12x12 11500rpm 80/20 fuel
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 81
RE: A NEW PATRIOT IS BORN!!! - 9/4/2008 6:15:25 PM
SpeedBoy
Status: offline
Beautiful Patriot
I love the pics
GENTLEMEN , START YOUR ENGINES ..... FEEL THE ADRENALINE !!!!!!!
REVVER BRO #206
(in reply to särpet)
       Post #: 82
RE: A NEW PATRIOT IS BORN!!! - 9/5/2008 3:56:09 PM
bob27s
Status: offline
Nice.....
That bird should fly quite nicely
Bob Brassell
       Post #: 83
RE: A NEW PATRIOT IS BORN!!! - 10/7/2008 5:54:49 AM
Razor-RCU
Status: offline
Good looking Finnish speedster there! Let us know how it goes...
Revver #5
       Post #: 84
RE: A NEW PATRIOT IS BORN!!! - 10/8/2008 8:33:47 PM
CARS II
Status: offline
Since you guys are talking about all kinds of Patriots here, here I come with mine, xl 60/90 size still in the building process, it has been a few years since I build a balsa kit and had forgotten how much fun this building bussiness is , I'm also building another airplane all wood too at the same time but the Patriot has priority, it will fly in about a month ( I hope )
I got me two sets of laser cut servo covers ( actually the servos get screwed to them ) from Laser Design Services to change the position the servos are mounted in the wings, I had to build a new NG mount to fit my 20+ old spring air retracts using a pull/pull system, will be using a 16 oz fuel tank ( I happen to have that size at home ) and will like to mount it right over the CG, I saw on the last AMA magazing a new fuel pump that will allow me to instal the fuel tank any were I want ( sweet ) will sheet the wings 100%, and have a pair of BVM wheels with brakes that I pick up at a swapmeet some time ago, since I will be using air for the retracts then I could use it for the brakes also I will be using a ST 90 on the nose, about which prop to use first not sure at the moment it all depends on the final dry weight but to start I guest I can use a 12/8 and 11/8 I'm also getting one of those black Mcpipes.
what you guys think????
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by CARS II -- 10/8/2008 8:40:34 PM >
CARS II
To infinity and beyond...........
(in reply to Razor-RCU)
       Post #: 85
RE: A NEW PATRIOT IS BORN!!! - 10/13/2008 8:10:48 PM
särpet
Status: offline
i try st .90 and it not like run over 13000rpm
http://lennokit.net/showthread.php?t=30229&highlight=super+tigre
(in reply to CARS II)
       Post #: 86
RE: A NEW PATRIOT IS BORN!!! - 10/19/2008 8:40:56 AM
SpeedBoy
Status: offline
quote:
ORIGINAL: CARS II
This is a video of a Patriot XL with a ST .90 and 13x8 APC (with pipe ) .This probably can give you an idea how will fly with it .
http://www.youtube.com/watch?v=LVRkDcSDom8&feature=related
REVVER BRO #206
       Post #: 87
RE: A NEW PATRIOT IS BORN!!! - 11/8/2008 4:22:11 PM
särpet
Status: offline
hello guys
ihave problems with engine fuel supply.
my tank is on balance point and iuse webra tank pressuring system and it not WORK.
where is yours fueltank and if its on front fuselage,how 400gr nose weight effect?
3flights today and 2 deadstick.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to SpeedBoy)
       Post #: 88
RE: A NEW PATRIOT IS BORN!!! - 11/9/2008 2:18:43 PM
vasek
Status: offline
If you're using only pipe pressure it might not be enough. Not sure if the device seen in your pic is a pump driven by pipe pressure. (?)
In any case you could try a "header tank" or "hopper tank". There's no need for pumps. Do a search here on RCU & you will find the info needed.
I am a proud Canadian >living in Europe;-)
