RE: Carden Profile
Tower Hobbies
Logged in as Guest
  Printable Version
OMP Edge 540 P 80 - "Original MOAP" - RTF
Seller:  bizjetplt
Details:   $1,395.00   |  7/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> RE: Carden Profile
Page: <<   < prev  2 3 4 5 6 7 8 9 10 [11]
Login
RE: Carden Profile - 4/10/2008 11:11:44 PM
Flexnbeef
Status: offline
I'll be over to check it out when I pick up the aluminum stock.. I'll call you first ..Is there a good time for you on sat morning?? Let me know..
_____________________________
I never crash, The plane does !!
(in reply to wessco)
       Post #: 251
RE: Carden Profile - 4/11/2008 2:51:14 AM
mrbigg
Status: offline
quote:
ORIGINAL: wessco
Looking nice mrbigg!
Thanksman. I'm starting to see the light at the end of the tunnel. Finished the gluing the end caps on the wings today. Did some sanding and a little filling also. One more final sanding in the morning and I'll start covering the wings.
Beef, anytime is good. Give me a jingle. Doesn't look to good for flying weather wise.
PROVERBS 15:22 - Plans go wrong for lack of advice; many counselors bring success.
       Post #: 252
RE: Carden Profile - 4/14/2008 8:50:47 PM
Flexnbeef
Status: offline
Man that thing sounded sweet.. Can''t wait to see it in the air . Your covering was clean and tight... Stopped by Johns today to get some things for the Eindecker and walked out with this thing .
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to mrbigg)
       Post #: 253
RE: Carden Profile - 4/19/2008 1:13:28 PM
Flexnbeef
Status: offline
Mr Bigg..... Any more progress????
(in reply to Flexnbeef)
       Post #: 254
RE: Carden Profile - 4/19/2008 1:28:09 PM
mrbigg
Status: offline
I spent about an hour and a half covering the bottom of the other wing. Should have the rest done by tonight and then get some pics up.
       Post #: 255
RE: Carden Profile - 4/19/2008 4:46:58 PM
Flexnbeef
Status: offline
cool ! I will be going to the field sunday morning....
       Post #: 256
RE: Carden Profile - 4/23/2008 9:38:25 PM
mrbigg
Status: offline
Some pics of the stabs. Stabs are about the same size as my .40 size SuDoKoi. Cutting the stripes were a hassle.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 257
RE: Carden Profile - 4/23/2008 9:43:27 PM
mrbigg
Status: offline
Finished up the covering. I went ahead and hinged everything as it was completed. I also sealed the hinge gaps. That's what took so long. I took the gear off and polished it. Also mounted the wheel pants.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by mrbigg -- 4/23/2008 9:53:56 PM >
       Post #: 258
RE: Carden Profile - 4/23/2008 9:49:59 PM
mrbigg
Status: offline
Here's the bottom. Influenced by QQ, you can tell. The whole plane is Ultracote except for the white, which is Monokote that I had laying around. I had just enough to do the job. I laid the stipes down one after another. The Monokote requires a higher temp than the Ultracote so I had to use a higher temp on the iron which was right at the Ultracote's upper heat limit.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 259
RE: Carden Profile - 4/23/2008 10:11:52 PM
wessco
Status: offline
That is a fine looking job. Any idea when you might maiden it?
       Post #: 260
RE: Carden Profile - 4/23/2008 10:20:46 PM
Strankon
Status: offline
Looking good Bigg! whats it weigh?
       Post #: 261
RE: Carden Profile - 4/23/2008 11:36:53 PM
mrbigg
Status: offline
wessco- I'm still debating engine choice.
Strankon- Haven't weighed the whole thing yet. The wings weigh about 3.5 pounds with no servo, horns, or linkage. Sounds like alot, but they are huge and foam core with 1/16" sheeting. Each panel is 52" long, 28" chord at the root and 14.5" at the tip.
(in reply to Strankon)
       Post #: 262
RE: Carden Profile - 4/24/2008 1:25:16 AM
Flexnbeef
Status: offline
That looks sweet !!! I like the wheel pants too..I got the Sicho's rudder repaired and put new pieces of ply on both sides of the fuse for the landing gear mounts.. Also I'm going to change the tank on the Edge to a 4 oz tank to see if helps with the weight. I will be in your area on sat to look at Dales plane so I might stop by if you are going to be home...
       Post #: 263
RE: Carden Profile - 4/25/2008 6:03:08 AM
Flexnbeef
Status: offline
here's that gear we talked about
Click for fullsize
       Post #: 264
RE: Carden Profile - 4/25/2008 1:37:48 PM
mrbigg
