RE: Carden Profile
Tower Hobbies
Logged in as Guest
  Printable Version
Ohio Model Products Fusion X3D - 90
Seller:  cdp2buck
Details:   $525.00   |  10/7/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> RE: Carden Profile
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Carden Profile - 1/3/2008 9:57:33 PM
mmattockx
Status: offline
That would be all up weight before fuel.
Mark
_____________________________
Waco Brotherhood #4
(in reply to Flexnbeef)
       Post #: 51
RE: Carden Profile - 1/4/2008 2:00:18 PM
Flexnbeef
Status: offline
Got the taper all done. added the ply for the tail wheel. The plans had just a big gap under the tailwheel ply so I put some foam under it to bolster it up a bit.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
I never crash, The plane does !!
(in reply to mmattockx)
       Post #: 52
RE: Carden Profile - 1/4/2008 5:02:42 PM
mmattockx
Status: offline
quote:
ORIGINAL: Flexnbeef
Looking good, beef. How did you cut the taper on a fuse this size? That sure is a lot of sheet balsa!
I have a Mojo kit about 75% finished right now, this makes it look like a tiny park flyer.
Mark
Waco Brotherhood #4
       Post #: 53
RE: Carden Profile - 1/4/2008 8:11:27 PM
Flexnbeef
Status: offline
That was the scary part. I clamped two steel pieces of stock to top and bottom then layed it on my belt sander until it was flush with steel stock. flipped it over and repeated for other side , did it again for small taper also. It was snowing balsa dust !!
       Post #: 54
RE: Carden Profile - 1/4/2008 10:18:54 PM
mmattockx
Status: offline
quote:
ORIGINAL: Flexnbeef
That's why I asked. I hate getting way into a structure and then having to do one of those no return kind of steps. Turned out good, though.
Mark
Waco Brotherhood #4
       Post #: 55
RE: Carden Profile - 1/6/2008 5:40:51 AM
Flexnbeef
Status: offline
Hey MrBigg, You still building ???
       Post #: 56
RE: Carden Profile - 1/10/2008 5:45:55 AM
Flexnbeef
Status: offline
Got a little done last night. Servo rails and hatch rails. also mounted the motor box.
Click for fullsize
       Post #: 57
RE: Carden Profile - 1/10/2008 2:42:49 PM
mrbigg
Status: offline
quote:
ORIGINAL: Flexnbeef
I've been messing around with the other one.
PROVERBS 15:22 - Plans go wrong for lack of advice; many counselors bring success.
       Post #: 58
RE: Carden Profile - 1/10/2008 8:00:03 PM
Flexnbeef
Status: offline
I saw your new pipes on the other thread. Going out to Dynamic Balsa Fri afternoon to pickup wing tubes and things. I'm going to nix the foam wings on this plane and save them for a Extra profile later. I'm not going to use the wings in the plan either. Going to do a set like the ones on my Edge. Hope to get alot done this weekend. I'll keep you posted!!. I got a question for you...What would be the longest acceptable control rod length on the elevator and rudder ?? Like I said before this thing calls for a pull pull setup on the elevators and rudder .. I would like to get away from the pull pull setup on the elevators but my fuse is narrow at the tail. I thought about mounting them on the stab..Any Ideas ???????????. also it calls for 2 high torque servo's per aileron Do you think this is a little overkill ? would I be ok with 1 high torque Or maybe 2 standard servos per wing ?? After all this plan was for a 180 size build..
(in reply to mrbigg)
       Post #: 59
RE: Carden Profile - 1/11/2008 12:06:33 AM
mrbigg
Status: offline
quote:
ORIGINAL: Flexnbeef
You can put them in the tail. Put some balsa servo rails back there. About a 1/4" thick. See if he has about a 1" diameter wing tube. I know he has a 1 1/2" left but it'll be overkill and add excess weight. Use only one aileron servo per wing, centered in the middle. The bare minimum I would use is Hitec 645 Metal Gear servo. Your getting into the bigger planes now and the cheap 15 dollar servos don't cut it. My Ultimate has over $800.00 in servos and about $80.00 in aluminum servo arms. Welcome to giant scale.
       Post #: 60
RE: Carden Profile - 1/12/2008 5:08:13 AM
Flexnbeef
Status: offline
Hey Bigg... Picked up some more stuff at Dynamic Balsa today. Checked out some of his planes uptown.. Got a start on the wings .
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 61
RE: Carden Profile - 1/12/2008 10:13:56 PM
Flexnbeef
Status: offline
another picture
Click for fullsize
       Post #: 62
RE: Carden Profile - 1/13/2008 3:48:19 AM
Flexnbeef
Status: offline
Getting closer !!! . Sill alot of sheeting , shaping and sanding work to do on the wings and fuse . Ran out of sheeting so when I go to the LHS I'll also pick up a tailwheel and fuel tank . Need to fab a set of landing gear. Also have to make the all important decision on what motor to put in it..
Click for fullsize
       Post #: 63
RE: Carden Profile - 1/13/2008 5:43:47 AM
wessco
Status: online
What size wood is your fuse built from? I like the taper on the rear of the plane, which gives it more of a hybrid look.
