mrbigg
IL, USA Status: offline
Since I've scrapped the idea of using my crashed Wildhare Extra, I've been searching for a new scratch build project. A local guy makes foam wings and also sells wing tubes. I went to get a tube off him and was thumbing though his book of available cores and I found he has wing, fin/rudder, and stab/elevator cores for the Carden 40% Edge 540 and Extra! Each wing panel has a span of a little over 50" and he said that the wing area is bit over 2,000. The fuse must be pretty wide on the Carden 40% because the wingspan on them is 114" to 118," I think. What I like about using these cores are the facts that Cardens are known to be excellent fliers and I would have a tapered wing, which is alot of work to cut each rib by hand. There is still a bunch of work to get the wings ready, but looks to be fun. I'm going to put a link here to a Carden build I've been following, that way you guys can see how the wings get put together. Edit. Here's the link. It'll take you to the first page, where he starts sheeting the stab at the bottom of the page. http://www.rcuniverse.com/forum/m_6437950/anchors_6437950/mpage_1/key_/anchor/tm.htm
_____________________________
PROVERBS 15:22 - Plans go wrong for lack of advice; many counselors bring success.
