SKYPYRO
AZ, USA Status: offline
hmm, this seems like a very familiar problem. A guy out at my field had a UCANDO with an OS 91 FX on it. Every day almost, he would fly it, go deadstick, take it apart, fiddle with the engine and fuel tank, put it together and say "I finally found out what the problem was, it was an easy fix." He would then taxi out, take off and fly away, only to have a flame-out a couple of minutes later. It turned out that the engine was overheating, causing it to idle good, fly up to 2/3rds throttle good, but not do full throttle or 3D manuevers because of the intense heat or the limited airflow. BTW, is 30% fuel reccomended for your engine? This could be the source of the hot engine.
_____________________________
"Being a hot-dog pilot is 1% inspiration, 1% perspiration, and 98% crashing"
