William Robison
Joined: 11/10/2002 From: Mary Esther, Florida, FL, USA Status: offline
RCA: [QUOTE]Originally posted by RCAdd1ct OK. Here are the results of my test flying. Without the cowl off it is getting hot to the touch with 5 full turns out on the main needle. That is max RPM backed off a 1/2 turn.[/QUOTE] Hot is OK, if too got to touch there's a cooling problem. But 5 turns seems a lot. Flow restriction? [QUOTE]I set up idle up on the TX where in flight would be 3500 RPM. I flew it 1/2 throttle to full throttle and it died on a full throttle vertical climb. This is with a header tank sitting right next to the engine.[/QUOTE] A header tank eliminates the once in a while air bubble, the engine still sees the total distance to the main tank as its fuel draw. [QUOTE]On this dead stick landing it broke off the header tank I had stuck onto the firewall. This saves me from removing it since it did not help me anyway. I am agreeing with whomever said it is an air leak. I am going to go through it and remove the dual tanks and put the single 16 oz tank on it. I am also going to move to large fuel line. I will also mount the fuel pump on the engine but not hook it up.[/QUOTE] Bad idea. The pump will be an additional restriction to the fuel draw. If you hang it, hook it up. [QUOTE]Lastly, I am going to go through and look for air leaks while I have the engine out of the plane (I have to drill out the firewall for bigger fuel line).[/QUOTE] Think the larger fuel line will do more good than anything else, except, perhaps, the pump. [QUOTE]These dead stick landings are ruining my reputation. [/QUOTE] You have a reputation? Haw. Bill.
_____________________________
Real Airplanes have Two Engines AMA 25139 - More than 40 years.
