Saito 180 flaming out
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Saito 180 flaming out
Page: <<   < prev  1 2 3 [4]
Login
Saito 180 flaming out - 4/11/2003 10:17:49 PM
SKYPYRO
Status: offline
hehe- maybe its had time to think about what it has done while in time-out, and would want to work for me Would you be willing to sell it to someone, or does it not deserve to fly again?
_____________________________
"Being a hot-dog pilot is 1% inspiration, 1% perspiration, and 98% crashing"
(in reply to RCAdd1ct)
       Post #: 76
Saito 180 flaming out - 4/12/2003 10:33:57 AM
RCAdd1ct
Status: offline
OK. I had one flight with the pump and I am impressed.
This may have solved all my issues. I am being cautiously optimistic as I only got one flight in today for testing.
If I get a streak of great flights I might call it fixed.
-RCA
       Post #: 77
Saito 180 flaming out - 4/12/2003 11:53:50 AM
William Robison
Status: offline
RCA:
I love my Perry pumps AND Perry carbs.
Bill.
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
       Post #: 78
I tried a Perry once.... - 4/12/2003 12:16:56 PM
Flyboy Dave
Status: online
....and only once....I did give it a final adjustment at the
end of the day....with a 3# sledge (no kidding)
Bill....repeat after me....
7B....7B....7B....7B....7B....(keep going)....
An engineer says.... "That won''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
       Post #: 79
Saito 180 flaming out - 4/12/2003 7:37:27 PM
RCAdd1ct
Status: offline
I was very skeptical about adding an oscillating perry pump.
I was thinking there is no way this thing is going to work. It has to be a gimmick to sell more stuff. When I had to back off the main needle 2 turns I thought to myself, "this just might work".
Then I got to fly for 8 minutes(instead of the usual 4). I threw every stunt I new at the plane. My smile just kept getting bigger.
I sure hope this wasn't a fluke and I will get to experience that much fun over and over again.
Thanks for everyones help and suggestions on this one.
-RCA
       Post #: 80
Saito 180 flaming out - 4/14/2003 6:41:39 AM
RCAdd1ct
Status: offline
Got two more flights in before the rudder servo stripped out.
I am officially calling it fixed.
-RCA
       Post #: 81
Saito 180 flaming out - 4/14/2003 6:47:49 AM
William Robison
Status: offline
RCA:
Glad to have another convert to the "Perry Pump Gang."
Now we have to convince you to use the carbs. Haw.
How on earth did you manage to strip the rudder servo? Were you hovering and bouncing the tail on the ground?
Bill.
       Post #: 82
Saito 180 flaming out - 4/14/2003 7:01:49 AM
RCAdd1ct
Status: offline
I always run cheap servos in a plane until I get the bugs worked out. Less pucker factor on dead stick.
I had a 3004 futaba servo on 5 cells and a long servo horn.
I was coming in for a landing in 15-25 mph winds with full flaps deployed. As I got about 2 ft off the deck the wind went away and it smacked a three pointer in the tall grass.
Now that it flies good it is time to put some good servos in it and make the radio gear reliable.
-RCA
       Post #: 83
Bill.... - 4/14/2003 7:53:28 AM
Flyboy Dave
Status: online
....sorry, Dude....I wouldn't give a dollar for a wheel barrow
full of Perry carbs..... :
Revver Bro #4.
       Post #: 84
Saito 180 flaming out - 4/14/2003 8:23:22 AM
William Robison
Status: offline
Flyboy Dave:
I would. Gladly.
Bill.
       Post #: 85
Yo, Bill....(my friend).... - 4/14/2003 9:05:28 AM
Flyboy Dave
Status: online
....try this experiment....put an O.S. 7B carb on one
of your 6550's (K&B) or a .46 Magnum front needle
carb....heh heh heh....then tell me what you think
about the Perry's.... :
There'll be a field day....
....on e-Bay......
Click to see fullsize image.
Click for fullsize
Revver Bro #4.
       Post #: 86
Saito 180 flaming out - 4/14/2003 9:22:26 AM
William Robison
Status: offline
DAVID!!!
A RED CHINESE carb on a pure dyed-in-the-wool American K&B!!!
That... That... That's BLASPHEMY!!!
Bill.
PS: But it's not as bad as using a Nipponese one. wr.
< Message edited by William Robison -- Apr 14 2003 8:27AM >
       Post #: 87
Saito 180 flaming out - 4/14/2003 9:55:42 AM
ram3500-RCU
Status: offline
Had the same problem with short runs and dead sticks on my cermark pitts with a 180. Here is what I did. Replaced the presure line from the muffler, switched to a type F plug, switched to YS 20/20 fuel, richened the low end adjustment 1/2 turn, and opened the high end by about 3/4 turn. Its propped with a 17/8 apc and runs like a different engine now. Mid and low ranges are solid and low to high response is instant. I always idle up in spins but don't bother anymore in all other maneuvers. I was going to pull this engine but i'm glad i didn't. With the 20/20 fuel I can get 20 min. flights on a 24oz. tank. Don't think 30% would go that far with the high speed opened up 5 or 6 like you 'd have to. Great engine Saito. I rely enjoy my Pitts now.
       Post #: 88
Jump to:
