William Robison
Joined: 11/10/2002 From: Mary Esther, Florida, FL, USA Status: offline
RCAdd1ct: I suspect, in all that violent flinging about, you just might be having the clunk get outside the fuel in the tank, drawing air instead of fuel. It can, and does happen. If it ends to flame out more often later in the flight this would be an additional indication of this condition. It will not happen in normal flight, nor in common maneuvers without rapid changes of "Relative gravity direction." But it has an easy cure - a bladder tank. This uses a flexible bag inside the rigid tank, fuel in the bag attached directly to the fuel feed pipe, (no clunk needed) and the pressure feed goes to the outside of the bag. Works like a champ. If you don't understand exactly what I mean, you can buy a Tetra bladder tank from Central Hobbies. Worth the money to cure your problem. HTH. Bill.
_____________________________
Real Airplanes have Two Engines AMA 25139 - More than 40 years.
