RE: Savage X SS Brushless Conversion Build-Discussion
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> HPI Monster Truck Forum >> RE: Savage X SS Brushless Conversion Build-Discussion
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Savage X SS Brushless Conversion Build-Discussion - 11/19/2007 3:20:21 AM
[]TEX[]
Status: offline
quote:
ORIGINAL: ravenlunatic
quote:
ORIGINAL: []TEX[]
Not as much torque with the 7XL, we picked the 8XL for it's torque and voltage I'm running. The Savage is heavy and we don't want to go too low on turns so the 8xl is as low turn as I'd go with 8th scale.
thanks for the info, i've contemplated this for a long time now and see as to how you've managed to make your own motor mount with ease, I will convert as soon as I can afford it. I curious to see how you will mount the batteries. It's looking real nice. by the way, what did you use to make your motor mount? (materials, tools, ect.)
If you were using a 5S Lipo you could get the 12XL and just be insane.
(in reply to ravenlunatic)
       Post #: 26
RE: Savage X SS Brushless Conversion Build-Discussion - 11/19/2007 3:22:57 AM
[]TEX[]
Status: offline
When you do, post your info here with pics!
       Post #: 27
RE: Savage X SS Brushless Conversion Build-Discussion - 11/19/2007 3:23:25 AM
ravenlunatic
Status: offline
thanks for your help, it's really cool that you take the time to explain things. i realy apreciate it as i find it hard to get specific advice. I can't wait to see the video, i'm sure your truck will tear it up
_____________________________
v-one-s, picco powered savage X ss, TT-01, xxx-s, X1 CRT, picco powered LST2, AX10
(in reply to []TEX[])
       Post #: 28
RE: Savage X SS Brushless Conversion Build-Discussion - 11/19/2007 3:48:13 AM
[]TEX[]
Status: offline
I made up some brick packs to power the Savage, I will mount them on either side of the motor bay. I plan to use the rest of the angle stock to make brackets for that.
Click to see fullsize image.
Click for fullsize
       Post #: 29
RE: Savage X SS Brushless Conversion Build-Discussion - 11/19/2007 4:20:25 PM
ravenlunatic
Status: offline
what kind of ESC are you using? it seems like you would need a pretty pricey one to use 14cells.
       Post #: 30
RE: Savage X SS Brushless Conversion Build-Discussion - 11/19/2007 5:19:35 PM
go-to
Status: offline
quote:
ORIGINAL: []TEX[]
Here it is hooked up and ready for testing. I did test it with a 7.2V pack and it works well. I still have to set up the esc correctly and I'm waiting for my ubec to be delivered.
Now if I can just find my spray cleaner to clear out the tranny.
What does UBEC stand for?
Savage X SS, FLM LCG TVP, Axial .28, 3-speed, 18/49
Savage 25, SureFire 32R RB Mods, 4-gears diff's, 2-speed, 18/47
       Post #: 31
RE: Savage X SS Brushless Conversion Build-Discussion - 11/19/2007 6:17:26 PM
dhyde79
Status: offline
ok, so here's the only thing I'm not following.....how're you controlling throttle/brakes? is that what the ESC does in the place of the throttle servo or what? (I can see how you'd get the throttle working, but, what about the brakes?)
SAVAGE IRC CHAT: irc.absurd-irc.net:6667 #savagechat
Java Based Client: http://www.shadowrungamers.com/savagechat/
(in reply to go-to)
       Post #: 32
RE: Savage X SS Brushless Conversion Build-Discussion - 11/19/2007 6:27:45 PM
SpikeX
Status: offline
dhyde79, the ESC controls the throttle, and reverse in some cases too (if it is fitted with reverse). Electric cars don't have brakes, as the motors slow down the car very quickly.
(in reply to dhyde79)
       Post #: 33
RE: Savage X SS Brushless Conversion Build-Discussion - 11/19/2007 6:56:51 PM
dhyde79
Status: offline
ok, so the motor acts as brake, reverse, and throttle all at once then? (except for on a savage, in which the reverse will still be at the reverse module in the transmission due to transmission design)
good to know, if I can shave a bit of weight I might just go that route, I'm not enthused by the idea of electric though, I went nitro for the run time potential.....
(in reply to SpikeX)
       Post #: 34
RE: Savage X SS Brushless Conversion Build-Discussion - 11/19/2007 7:10:48 PM
ravenlunatic
Status: offline
quote:
ORIGINAL: dhyde79
hmm...you know this brings up a good point. how would the struck stop if the spur spins in reverse freely? as i remember the transmission is forward only and the spur will still spin freely in reverse when the truck is sitting still.
       Post #: 35
RE: Savage X SS Brushless Conversion Build-Discussion - 11/19/2007 7:15:47 PM
go-to
Status: offline
By leaving the throttle/brake servo intact and functioning as normal. You can set the ESC and brushless motor to not have any brake when applied...so your stock setup does it for you.
And you can always use the Reverse mixer where you hold the transmitter brake for like 3secs and the reverse module engages.
< Message edited by go-to -- 11/19/2007 7:18:27 PM >
       Post #: 36
RE: Savage X SS Brushless Conversion Build-Discussion - 11/19/2007 7:25:19 PM
ravenlunatic
Status: offline
ah... i see what your saying. so then you would use the receiver with the throt/brake servos as well as the ESC. silly me i fogot about the receiver thats pretty cool.
(in reply to go-to)
       Post #: 37
RE: Savage X SS Brushless Conversion Build-Discussion - 11/19/2007 7:28:01 PM
dhyde79
Status: offline
...or a 3 channel radio and just use the reverse switch.....
with the transmission setup on the savage as it is, I'm not following how the brakes will actually function since we've just pointed out that slowing the motor won't necessarily slow the truck......(think about it, if your engine dies while running, your truck doesn't lock the brakes and slide to a stop)
(in reply to go-to)
       Post #: 38
RE: Savage X SS Brushless Conversion Build-Discussion - 11/19/2007 7:37:36 PM
go-to
Status: offline
quote:
ORIGINAL: dhyde79
