JR 10X travel volume question
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Smart-Fly (Quest Engineering) Support Forum >> JR 10X travel volume question
Page: [1]
Login
JR 10X travel volume question - 11/18/2007 3:10:20 PM
DCGayhart
Status: offline
I’m installing an EQ10 in my 35% Yak formerly equipped with two R2000 JR receivers to split the control functions with matchboxes on the ailerons. I use a JR 10X transmitter and my question is what do I set the travel volumes at in the TX before beginning set-up?
I think I read somewhere you set the volumes at max minus some percentage but it’s not mentioned in your instructions.
Thanks Danny
       Post #: 1
RE: JR 10X travel volume question - 11/18/2007 4:19:42 PM
quist
Status: offline
I set them at around 135. Then program your servos. Below is how I do it.
I program the inside wing servo with the transmitter for centering and endpoints. I plug this servo into port one in the eq10. Then I use the eq 10 to match the ganged servo(s) that are plugged into port 2 or 3.
(in reply to DCGayhart)
       Post #: 2
RE: JR 10X travel volume question - 11/18/2007 4:47:57 PM
DCGayhart
Status: offline
135 sounds logical that would be 150 minus 10%.
(in reply to quist)
       Post #: 3
RE: JR 10X travel volume question - 11/18/2007 5:52:27 PM
rrritchey
Status: offline
Hi Danny,
Tony actually has more experience setting up planes than I do using the Eq10 and other Smart-Fly products so I would use his recommendation. What I always tell people is to always make adjustments using the hi-rates. Where you set your high rates on the travel volume is usually a personal preference.
_____________________________
Robert Ritchey
Owner, Smart-Fly
       Post #: 4
RE: JR 10X travel volume question - 11/18/2007 11:41:33 PM
DCGayhart
Status: offline
I split the differance and use 140.
Danny
(in reply to rrritchey)
       Post #: 5
RE: JR 10X travel volume question - 11/19/2007 12:14:24 AM
quist
Status: offline
That will work fine. There aren't many absolutes on radio setup.
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.563RCU1
