Red B.
Joined: 8/29/2002 From: Jonkoping, SWEDEN Status: offline
quote:
ORIGINAL: vmsguy Nice SSE!!! I've been considering one for some time... I have a couple quick questions. 1. I noticed you used pin hinges. Could you tell me more. Size, brand, etc. Looks like you used 4 on each aileron, 3 on each flap. Sorry, I don't know the brand. They may be German Kavan ones. quote:
2. Looks like you have all for servos connected the same, the "inside" arm of the servo is connected to the flap or aileron. I presume you're using a Y cable on the aileron servos, then each flap servo on its own channel, then letting the radio sort it all out? All four servos are connected to individual channels. No Y cables are used. In that way I have full freedom to do any mixing I want, e.g., elevator-flap mixing, crow, flaps with drooping ailerons, and aileron to flap mixing for those times when I want maximum aileron response. quote:
3. Reinforcing wires on the stab/rudder? Is that a mod? No, it's according to the plan. With the exception of the flaps and the tail wheel (Du-Bro) it is a standard SSE. The covering is Monokote Pearl Red and Pearl White.
_____________________________
/Red B.
