iron eagel
Joined: 7/15/2004 From: Middleboro, MA, USA Status: offline
quote:
ORIGINAL: alex7403 Why do you guys like cowls so much, IMO it adds complexity and source of issues… My TT trainer had a cowl, I damaged it all the time until there was nothing to glue anymore then I started enjoying flying the plane, it was ugly tough. I like sigs because of those cheeks. Paul, Regarding the weight removal I have the opposite problem, I’m adding weight in form of reinforcements that not always needed. you have a big motor and its possible to get a bigger motor why are you trying to remove weight all the time? In my midstar take off happened as soon as ¾ throttle was reached, no need to remove weight. Alex, There are many others that are far more qualified to answer your questions on RCU than myself, BMatthews, CaffeenMan, Dick Hanson, Da Rock to name a few but I will take a shot at it. As Somegeek said regarding the cowl because it looks good is one reason, my SSE will not look like the others at my field. The other reason is the improved aerodynamics; it will reduce the drag on the airframe by reducing the high pressure areas at the front of the plane, and allowing a less turbulent (cleaner) undisturbed airflow along and around the fuselage. In my case there is also the fact that I am looking to increase the side area of the fuselage to improve the knife edge performance of the airplane. Others have tried adding side force generators, increasing fin and rudder area with success but this is the route I chose to take. Yes it is a bit more complicated and probably more of a PIA than not having a cowl but I feel the improved performance more than makes up for the complication to the plane it adds. Now as far as the weight yes it is nitpicking but as Somegeek said it keeps the wing loading lower. As you increase the weight and wing loading of an airplane you decrease its performance. The increased weight increases the stall speed and decreases the stall angle, simply put the airplane will stall easier. But that is not all, as you add weight you are calling on the wing to produce more lift, and when the wing produces more lift it also produces more drag, which requires more power to keep the airspeed up. Granted you can add an even larger engine for more power but you add more weight, need more lift produce more drag in a vicious circle. By keeping the weight down you are actually reducing the horsepower needed to perform lowering the power requirements and thereby effectively adding available horsepower, simply by reducing the amount of power needed. Not to mention since F=M*V by keeping it lighter it hits the ground with less force and the plane will be damaged less. Regards, Paul
< Message edited by iron eagel -- 1/21/2008 9:12:12 PM >
_____________________________
The Wrights never crashed, they only had hard landings. I 've had some hard landings myself. AMA EAA AOPA revver #185
