iron eagel
Joined: 7/15/2004 From: Middleboro, MA, USA Status: offline
I can not wait to see it at the field either.... Hand to make a trip over th Hanson Hobby to pick up some stock for the fairings and alike. The tail feathers are going have both fairings and fillets, probably overkill on this plane, but a good way to practice them before I do the scale ones I want to build. After the glue had time to cure this afternoon I tried stressing the horizontal and vertical stabilizer to see how my carbon fiber spars worked to eliminate the external tail braces. Nice and stiff no problem as far as strength that I can feel so it should work out nice. Normally when I have to cut the notch for the elevator joiner out of a tail fin like this model, I have some concern about weakening the structure, I do not see that being a problem here at all. You saw how the carbon fiber worked out on the rudder I brought to the meeting the other night, same thing here and I haven't applied the veil yet. I am working on finishing the skin of the fuselage on the tail that I had left open so I could anchor the carbon fiber to the bottom of the fuselage then I will do the fairings and fillets. Then the next step will be to start on the pressure cowling, and cooling duct. I ordered landing gear from TNT over a week ago but they have not turned up yet. And where they are going to be embedded within the cooling duct I really would like to have them here when I build that part. The cooling duct will be a bit more involved because it is going to have an expansion chamber and nozzle built into it. I want to see if Andy Lennon's theory about using thermal expansion from the waste heat of the engine to produce thrust works. From what I gather from reading his explanation is that it works somewhat like a ram jet. Hey, if nothing else it will get the guys asking; "whats that all about" when they see it.
_____________________________
The Wrights never crashed, they only had hard landings. I 've had some hard landings myself. AMA EAA AOPA revver #185
