iron eagel
Joined: 7/15/2004 From: Middleboro, MA, USA Status: offline
reincarnate, I love how you finish came out! Don't worry about the Hijack I haven't been posted for a bit anyhow. I cant wait to see how the weight of mine comes out with the fuselage being fully sheathed, I have taken some care to trim as much weight as I could but, still will not have an idea of the finished weight till I have the servos tank and radio in. The tail feathers came out close to the stock weight (3/4 of an inch to the elevators, 1.25 inch to the rudder) not much of a savings their unless you take into consideration the enlarged control surfaces. Tanks for posting the rtf weight of your build, it will give me an idea of what I can expect. I am now on my third version of the cowl, the first two I did not come out looking even close to what I wanted, so I trashed them. While this plane is not built for speed I still wanted something that was fairly clean and would improve the airflow over the fuselage. By adding some control surface area to the tail and the added side area of the cooling duct should give it a bit better knife edge performance, at least that is the plan. All of the control surfaces with the exception of the flaps are being set up as pull pull hopefully that will help keep the weight down a bit I still have yet to fish the cables through the wing but that should not be a big deal. I have to go out this afternoon but hopefully tonight and tomorrow (my weekend) I will have a shot at getting the cowl done. Our flying field is still a bit of a swamp, so no real rush to get out and fly during mud season for me.
_____________________________
The Wrights never crashed, they only had hard landings. I 've had some hard landings myself. AMA EAA AOPA revver #185
