iron eagel
Joined: 7/15/2004 From: Middleboro, MA, USA Status: offline
As you pointed out the Sig Somethin Extra actually flies fine with no or very little modifications and is a nice airplane as it is. I just decide to kick it up a few notches, and if you take the time to do some more modifications you can really kick it up a several notches. This build was intended to hone my building skills, after years of absence from the hobby, and gain some knowledge of new materials, before I move on to some more esoteric aircraft. More than anything it is just a fun experiment at trying some new things and ideas. Where I can not ever build an airplane totally stock, I just took it to an even higher level with this one. I enjoy building as much if not more than flying sometimes and during the winter months and bad weather, it is a good way to keep playing with airplanes. Since I had this kit to build and had a reason for flying an airplane that was aerobatic as well it fell victim to my ideas for improvement. Had I not had a major problem with my health, I would have had it done a month ago, but I have been able to work on it more of late. In this build I went with the taller landing gear and an upgrade to the tail wheel to allow for the use of a bigger diameter prop on the OS 55 AX that I selected for power. Many others have enlarged the rudder and elevator to enhance the performance so I did so as well. What I threw in was a few more enhancements to the overall design. One was to beef up the tail structure to eliminate the tail braces. To me they detract from the overall look of the plane as adding a lot of drag. I had also wanted to experiment with a pressure cowl as well, and the entire arrangement was built to add an enhancement to knife edge performance as well as, eliminating drag from the stock nose. The enhanced knife edge performance should result from side area that is added ahead of the COG by the cowl and cooling duct. Where I intend to build a couple of airplanes that where going to utilize the pressure cowl concept in the future I wanted to experiment with it now since I was building a kit I and saw some possible room for improvement at the same time. Along with all of that I decided to enhancement of the wing attachment to the fuselage was not all that bad of an idea either. Now you have some more insight as to what I am doing with this build... I did not have a chance to work on it yesterday or today because of the heat but they tell us that it should cool down a bit tomorrow. Overnight it seemed the temperature shot up by some 50 degrees and it was hard for me to get acclimated to that type if a change in three days, it was dam near 100 today and Friday it was around 50.
_____________________________
The Wrights never crashed, they only had hard landings. I 've had some hard landings myself. AMA EAA AOPA revver #185
