f3a05
Joined: 3/12/2005 From: Saffron Walden, UNITED KINGDOM Status: online
Further notes from an electric novice… My Dualsky 11T motor efforts had to end---it killed my Hyperion ESC in a very short first flight as detailed in another thread, then ran into what seemed like massive (90A+) over-current problems when tried with a Castle Creations 85HV ESC. My UK supplier didn’t seem to want to investigate the motor, beyond advocating “hard timing” (which I had tried without success)----but was willing to refund the motor’s cost---so that’s that for the Dualsky… Until I can obtain another one from the US. For the moment, I’m using an Axi 5330 F3A, CC 85HV ESC, Flightpower 5350 F3A pack, APC 20.5X14. I ran into what seems to be a common problem from several threads on here----namely a nasty shrieking noise,accompanied by slowing of the motor, on advancing the throttle. Remedies suggested seemed to fall into two groups---(a) involving reducing supply-side resistance as much as possible(short leads, bigger connectors, soldering instead of connectors &c.) None of this made any difference. (b) involved altering the timing. Most advice seemed to incline to advancing the timing---this didn’t work for me----but a small remark on some Castle Creations instructions (that their soft timing option was advised for out runners---the opposite to advice elsewhere) ------As a last resort, I tried the soft timing option---and it works!! The Axi runs smoothly between 0 rpm and WOT of 6000rpm, so the soft timing doesn’t seem to have affected the power. What timing options are others using?
