RE: Dualsky 6360-12T props
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: Dualsky 6360-12T props
Page: <<   < prev  1 2 3 4 [5] 6 7 8   next >   >>
Login
RE: Dualsky 6360-12T props - 4/12/2008 2:23:29 AM
RC_Pattern_Flyer
Status: offline
Now, the next one is a bit more difficult because two bearings are press fit into the center of the stators.
In the picture i only show one bearing i noticed, but there are two as you shall see later.
Click to see fullsize image.
Click for fullsize
_____________________________
Mark Hunt Designs
(in reply to RC_Pattern_Flyer)
       Post #: 101
RE: Dualsky 6360-12T props - 4/12/2008 2:25:09 AM
RC_Pattern_Flyer
Status: offline
Here is what you end up with, total parts and also the disassembly summary shot...
Click for fullsize
Click for fullsize
Mark Hunt Designs
       Post #: 102
RE: Dualsky 6360-12T props - 4/12/2008 2:28:32 AM
RC_Pattern_Flyer
Status: offline
I hope this helps, dont be afraid to tackle this... just take care and plan ahead to have the proper tools...
If you have any other questions, please feel free to pm me and I will get back with you.
I flew the 6350 all last year on a 10.2 lb 2M Pentathlon (pictured <---- ) and had great success.
This year I will be flying the 6360 -12T using either the 21X13W or the 20X15.
Good Luck
Chuck Hochhalter
Team Dualsky USA
Team 2DogRC
Mark Hunt Designs
       Post #: 103
RE: Dualsky 6360-12T props - 4/14/2008 8:58:51 AM
Paul_K
Status: offline
quote:
ORIGINAL: RC_Pattern_Flyer
I flew the 6350 all last year on a 10.2 lb 2M Pentathlon (pictured < ) and had great success.
Good Luck
Chuck Hochhalter
Team Dualsky USA
Team 2DogRC
Chuck Hochhalter: Thank you very much for a most thorough and detailed description. I managed to change my bearings this weekend without problems. The buzzing noise at about 50% throttle didn''t dissapear though. My motor''s bell is not completly true, so I suspect that the noise may be related to that.
       Post #: 104
RE: Dualsky 6360-12T props - 4/15/2008 2:45:30 AM
patternflyer1
Status: offline
Paul, are you firewall mounted with the A adapter?
I had my bearings go out this weekend so I put in my backup. I noticed where the A adapter bolts on that 2 of the 5 arms were cracked all the way through. I had the same 60% noise you do. Changed esc''s made no difference. Put in the new motor, no noise. Only thing different in the two that I can see is the crack. Just a thought, but check yours.. Guess I got lucky by finding this early.
Chris
Click for fullsize
Click for fullsize
www.airtronics.net
(in reply to Paul_K)
       Post #: 105
RE: Dualsky 6360-12T props - 4/15/2008 4:30:35 AM
shannah
Status: offline
Hi Chris,
Great meeting you this weekend.
I''m heading out to the shop to see if I have the same issue. Mine has been getting noisy lately.
Steve.
(in reply to patternflyer1)
       Post #: 106
RE: Dualsky 6360-12T props - 4/15/2008 4:39:05 AM
patternflyer1
Status: offline
I told you I noticed a noise in yours Steve.. After checking my bearings, they are rough while cold, but still spin good. I''m sure when they heat up they are crazy noisy which was what happened..
FYI, I emailed 2dogrc with the pics maybe two hours ago, they already had a reply from Dualsky with a replacement motor. Good customer service.. They said this problem was a problem with some of the motors that has been fixed.. Hopefully my backup that I bought at the same time doesn''t rip the nose off like yours.. lol.. Cause then a replacement airframe will be the cost.. As you know..
Nice meeting you also this weekend. Was some good conversations, and great flying!! Welcome back!!
Chris
www.airtronics.net
(in reply to shannah)
       Post #: 107
RE: Dualsky 6360-12T props - 4/15/2008 4:39:17 AM
shannah
Status: offline
No cracks on mine. I do, however, notice a bit of play when I grab the prop and twist it fore and aft.
       Post #: 108
RE: Dualsky 6360-12T props - 4/15/2008 6:02:43 AM
Paul_K
Status: offline
quote:
ORIGINAL: patternflyer1
I had my bearings go out this weekend so I put in my backup. I noticed where the A adapter bolts on that 2 of the 5 arms were cracked all the way through. I had the same 60% noise you do. Changed esc''''s made no difference. Put in the new motor, no noise. Only thing different in the two that I can see is the crack. Just a thought, but check yours.. Guess I got lucky by finding this early.
Chris
Chris: Yes my motor is firewall mounted. I will check this as soon as I get home. Thank you very much for bringing this to our attention, and for the pictures. I will report back.
Paul
       Post #: 109
RE: Dualsky 6360-12T props - 4/15/2008 7:10:01 PM
OhD
Status: offline
Good Luck
Chuck Hochhalter
Team Dualsky USA
Team 2DogRC
Chuck, you mention the proper tools but don''t describe them. It is not clear how you push/pull the double bearings out. Do you have a dowel of just the right diameter? How do you hold the assembly when pounding the bearings out? Any heat applied?
I''m at about 210 flights now and haven''t had it out of the plane yet. No change in noise or performance as far as I can tell. Bought another one for my new plane.
Jim O
       Post #: 110
RE: Dualsky 6360-12T props - 4/15/2008 9:25:47 PM
Paul_K
Status: offline
quote:
ORIGINAL: Paul_K
I had my bearings go out this weekend so I put in my backup. I noticed where the A adapter bolts on that 2 of the 5 arms were cracked all the way through. I had the same 60% noise you do. Changed esc''''''''s made no difference. Put in the new motor, no noise. Only thing different in the two that I can see is the crack. Just a thought, but check yours.. Guess I got lucky by finding this early.
Chris
Paul
Well I inspected my motor this evening and guess what I found: One of the arms is cracked all the way through. I'm getting a bit nervous about this motors. I'll report back on how the Norwegian dealer handles this. I think all Dualsky owners should have a good look at their motors............
Click for fullsize
Click for fullsize
< Message edited by Paul_K -- 4/15/2008 10:28:50 PM >
       Post #: 111
RE: Dualsky 6360-12T props - 4/16/2008 2:33:58 AM
patternflyer1
Status: offline
Very interesting Paul..
I got a response back really fast from 2dogrc and they contacted Dualsky.
This is their response:
Hello,
Dualsky has noted that there was a propblem with some of the motors that has been fixed. Please contact our warehouse tommorow to get a replacement motor.
I called today and they are sending a replacement. But now I am wondering if it''s worth risking my plane. That sucks because I like the motor. Doesn''t quite have the power of the Axi like I thought though.. Although mine''s the 11T..
Another thing I have noticed is that where the aluminum meets the black part of the can, one side of the aluminum has a 3/32 gap while the other is tight. Not sure if it was always that way, or if it has pulled out..
I''m glad I mentioned it now as I almost didn''t want to bring it online due to past issues with that..
C
Click for fullsize
www.airtronics.net
       Post #: 112
RE: Dualsky 6360-12T props - 4/16/2008 8:17:52 AM
Paul_K
Status: offline
Hello,
I called today and they are sending a replacement. But now I am wondering if it''''s worth risking my plane. That sucks because I like the motor. Doesn''''t quite have the power of the Axi like I thought though.. Although mine''''s the 11T..
I''''m glad I mentioned it now as I almost didn''''t want to bring it online due to past issues with that..
C
The Norwegian dealer Rcnet just got back to me, and they are sending me a replacement motor. Excellent service. I will fly it and check it regularly. As some people is reporting over 200 fligths without issues, this can''t be a common failure. I like the motor as well, and would like to get one more for another plane if this one holds up. Mine is a 11T as your''s.
It seems to me that this could be avoided if the motor''s can where molded without these realitively sharp corners in the arms. A more rounded shape would not develop cracks that easy. Just my opinion....
Paul
< Message edited by Paul_K -- 4/16/2008 8:23:28 AM >
