Dualsky 6360-12T props
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> Dualsky 6360-12T props
Page: [1] 2 3 4 5 6 7 8   next >   >>
Login
Dualsky 6360-12T props - 11/19/2007 11:06:14 PM
shannah
Status: offline
What is the consensus on prop size for the dualsky 6360-12T? In reading previous posts I see guys are using 20x15 and 21-14. Any recommendations?
       Post #: 1
RE: Dualsky 6360-12T props - 11/19/2007 11:28:18 PM
woodie
Status: online
quote:
ORIGINAL: shannah
20.5 x 12W is slow but a real tractor on uplines and good brakes on downline
20.5 x 14 is pretty good all around prop good speed but less braking
21x13 is good combination of tractor and braking
20x15 for those special windy days
22x12 slower, good tractor and good downline braking
All sizes refer to APC props
Woodie
(in reply to shannah)
       Post #: 2
RE: Dualsky 6360-12T props - 11/20/2007 12:21:00 AM
shannah
Status: offline
Thanks!!
(in reply to woodie)
       Post #: 3
RE: Dualsky 6360-12T props - 11/20/2007 12:44:51 AM
OhD
Status: offline
Don, any comments on the new batteries? Are they holding up"
Jim
       Post #: 4
RE: Dualsky 6360-12T props - 11/20/2007 12:48:01 AM
ual767
Status: online
You might try the 21-14 as well. Dave S. has been trying it out and it seems to work well I have one on my test plane with a few flights on the 21-14 and it seems like another good option.
_____________________________
If you never try anything new, you''ll miss out on many of life''s great disappointments
(in reply to OhD)
       Post #: 5
RE: Dualsky 6360-12T props - 11/20/2007 1:24:48 AM
woodie
Status: online
quote:
ORIGINAL: OhD
Jim
So far they are. About 30 flights on them and I haven't been gentle. Don
(in reply to OhD)
       Post #: 6
RE: Dualsky 6360-12T props - 11/21/2007 6:31:28 PM
Dean Pappas
Status: offline
So how do you like the Dualsky 6360?
At that price, I've got to know!
Dean Pappas
       Post #: 7
RE: Dualsky 6360-12T props - 11/21/2007 10:17:03 PM
OhD
Status: offline
quote:
ORIGINAL: Dean Pappas
Dean Pappas
I've got about 150 flights on mine and I find it very consistent. So far zero maintenance. Less than a buck a flight and getting less every flight. Now if we can get 200 flights out of $200 worth of battery packs, the cost per flight favors electric.
I still like the 22x12 better than the 20.5x14. The 20.5x14 might do better on the 11T. Maybe a winter project.
Jim O
(in reply to Dean Pappas)
       Post #: 8
RE: Dualsky 6360-12T props - 11/22/2007 2:09:05 AM
woodie
Status: online
Dean Pappas
I have over 300 on my original 6360-12T with no maintenance other than replacing the bearings early on. I thought they needed replacement but it made no difference and the replacements have gone over 250 flights so far. Others have had to replace bearings because the motor got 'noisy' but the bearings are real cheap to replace. Standard inline skate sizes. One large and 2 smaller bearings. Costs about $12 to replace all three.
Don
       Post #: 9
RE: Dualsky 6360-12T props - 11/22/2007 6:14:26 AM
shannah
Status: offline
Looks like I'll have to order a few more props and give them a try. I think I'll need a new spinner also since it seems that the Dualsky has a 8mmx1.25. The axi has a shaft the size of a baseball bat. Does the dualsky fit an APC prop without having to ream it out?
       Post #: 10
RE: Dualsky 6360-12T props - 11/24/2007 4:45:25 PM
RC_Pattern_Flyer
Status: offline
slight amount of reaming is required to fit the APC
Chuck Hochhalter
Mark Hunt Designs
       Post #: 11
RE: Dualsky 6360-12T props - 11/25/2007 12:12:22 AM
patternflyer1
Status: offline
quote:
ORIGINAL: shannah
I ordered some cheap bearings for the prop shaft difference between the axi and the dualsky.. Found them on E ba y.. They have the inside dimension of 8 mm and outside 12mm.. I didn't have to buy a new spinner, or new props.. Works great..
Chris
www.airtronics.net
       Post #: 12
RE: Dualsky 6360-12T props - 11/25/2007 12:31:17 AM
shannah
Status: offline
Good idea. I think I'll try that.
(in reply to patternflyer1)
       Post #: 13
RE: Dualsky 6360-12T props - 11/25/2007 2:07:12 AM
patternflyer1
Status: offline
quote:
ORIGINAL: shannah
It works well... The bearings are made by Duratrax. You can probably find them at your LHS.. Saved me alot of money in spinners and props..
Attached are a few pics of how I used them on my Abbra..
BTW... I'm running the 11T on a 22x12 and it has almost the same power as the Axi F3A motor IMO.. Didn't like it on a 20x13.. Which is what I liked on the F3A.. Good motor though.. I'd recommend it.. And have.. lol
Chris
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
www.airtronics.net
       Post #: 14
RE: Dualsky 6360-12T props - 11/25/2007 3:41:36 AM
shannah
Status: offline
I was wondering what the performance difference was between the 11T and 12T. It seems that both are being run. What's the power difference between the two?
       Post #: 15
RE: Dualsky 6360-12T props - 11/25/2007 5:30:56 AM
OhD
Status: offline
quote:
ORIGINAL: shannah
I believe they are both rated at 2400 watts. The difference is prop load times rpm. If you want more rpm with a smaller prop go for the 11T. If you want a larger prop go with the 12T. I suspect Chris is over 2400 watts with the 11T and 22x12. Then again we only average about 900 Watts flying pattern so maybe the motors can take more peak power as long as the average is low enough. Right now we are kind of battery limited so we don't push the motors too much.
Jim
       Post #: 16
RE: Dualsky 6360-12T props - 11/25/2007 6:54:30 AM
shannah
Status: offline
Thanks Jim.
I am waiting for the 12T to arrive. I am running the Axi now, but am looking forward to the comparison with the Dualsky 12T. I like the numbers with the 12T and a larger prop, since a larger prop will probably do better on my plane. These motors are relatively inexpensive so its feasible to try different combos. Heck, the Dualsky doesn't cost much more than a 40%
