Flyboy Dave
CA, USA Status: offline
I was thinking about this topic (ARO) on Thanksgiving day driving out to my Mom's house, about 4 hour round trip. I was day dreaming about when I was working as the service manager in the later stages of my motorcycle mechanic career....almost 20 years of nothing but engines of all sorts. A guy walks up to the service window and says...."I squirted a bunch of automatic transmission into the crankcase of my engine". My immediate reaction was to wonder why on Earth would someone do that ! He said he wanted to make sure he had rust protection on his bearings. I kept a straight face. Another young man walks up to the window with another bike and tells me he squirted a bunch of air tool oil into his engine....to prevent his engine from rusting. Both bikes wouldn't run because the oil was fouling the plugs. Again I keep a straight face as I quote our customer a price to flush out his engine of the foreign material, and get the machine back into proper service....an hours labor will suffice. Did it ever occur to you ARO users to use some proper oil ? I'll bet you read about this ARO thing on the Internet, or saw someone using some at the field, and got the bug to use some yourself. And since the guys are using these concoctions of garage mixed fluids, you supposed it would be proper as well. How about using a fluid that is specifically designed to lubricate your engine ? Keep in mind that neither ATF of air tool oil oil is meant to be burned in an internal combustion engine. How about an oil that is specifically designed to prevent rust in your engine, and the best part....an oil that is designed to burn as a mix....and best of all, it burns absolutely clean. Did it ever occur to anyone to use an ARO that is compatible with the oil that is already in most aero-model fuels ? Probably not, but is has occurred to me. Is your fuel pink or red in color ? Most fuels used to be, and a lot of them still are. That pink color is from the Klotz two cycle oil in your fuel. It has been a staple of lubricants since the early 70's, and it is a good oil. In fact it looks a lot like ATF coming out of the bottle. This oil would make an excellant ARO because it is compatible with the oil that may already in your fuel, it burns clean, it mixes with anything, and is readily available at you local motorcycle shop, or off-road center. What a concept, huh ? An oil that does expressly what you want it to do, in spades. (lemme post this before I lose it somehow ) FBD.
_____________________________
An engineer says.... "That won''t work". A mechanic says..."Oh yeah, watch this". "Old Age, and Treachery will overcome youth and skill". Revver Bro #4.
