Flyboy Dave
CA, USA Status: offline
quote:
ORIGINAL: vertical grimmace The warning should say"do not use Morgan fuels"! I moved away from them long ago as I do not trust their oil. .....I would never use Cruel Power in any of my engines, for any reason. I rather like my expensive little aero-model engines, and I treat them with the greatest care. I've never had a rusty bearing in almost 40 years, and I used to live in the Harbor of Los Angeles, where the salt air would ruin all metals exposed to the atmosphere. I think my success was primarily due to using castor oil, and plugging off the exhaust to prevent oil from dripping out all over the place in the home. I have never used ARO. Think about this....the methanol in the fuel is hygroscopic. It draws the moisture from the air. The moisture (water) is what causes the rust, this is not a secret. If you run the excess fuel out of the engine with the fuel line disconnected, you will eliminate most of the problem right there. No methanol....no drawing in the moisture. If you close the carb you will seal off the front of the engine, and plugging the outlet of the exhaust with a wad of paper towel seals the engine against air and moisture getting into the engine. No moisture....no rust. The third part of the equation is the castor that helps prevent rust. I believe if you employ these three things, rusty bearing will be a thing of the past. FBD.
_____________________________
An engineer says.... "That won''t work". A mechanic says..."Oh yeah, watch this". "Old Age, and Treachery will overcome youth and skill". Revver Bro #4.
