FMA Announcing Cellpro 10s Charger
Tower Hobbies
Logged in as Guest
  Printable Version
NEW TENERGY 30C 2200mah 3s Lipos - FREE SHIPPING
Seller:  punkindrublik
Details:   $55.00   |  8/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> FMA Announcing Cellpro 10s Charger
Page: [1] 2   next >   >>
Login
FMA Announcing Cellpro 10s Charger - 11/20/2007 1:40:39 PM
Red Scholefield
Status: offline
Get ready for the most powerful, full-featured charger from FMA yet.
Once again, FMA redefines the capabilities of cutting edge charging technology.
They are putting the final touches on their new 10s charger design, and look to go into full production and
delivery of this powerful charger by mid-January time frame.
Look for these features and more when the Cellpro 10s Charger comes to market
Includes all the features of the popular Cellpro 4s Charger plus:
Up to 10A Max Charge Current
Continuous Power 300W (estimate)
Charges 1 Pack of 1s-10s or 2 Packs of 1s-5s Simultaneously
Includes Start/Stop Button
Backlit Liquid Crystal Display
Supports 2-way P.C. Interface
Displays Individual Cell Internal Resistance to 0.1 mohm Accuracy (Battery Quality Indicator)
Drive the Charger from the P.C.
Access Advanced Features from the P.C. (Setup Custom Presets, Adjust Speaker Volume, LCD Contrast, and More)
Integrated Upgradability (IU) Feature -- No need to send the charger to the factory for firmware upgrades again. Do it over the internet.
_____________________________
Red S.
AMA 951 Leader Member
       Post #: 1
RE: FMA Announcing Cellpro 10s Charger - 11/21/2007 7:24:36 AM
RC David
Status: offline
Red,
That's great news as I'm a new Li-Po user and will be in the market for a high quality 2-6 cell Li-Po charger very soon. This might be the ticket for my needs.
I didn't see it on the FMA website though.
Do you know if it will be a "balancing" charger or will you need a seperate balancer?
Dave D.
(in reply to Red Scholefield)
       Post #: 2
RE: FMA Announcing Cellpro 10s Charger - 11/21/2007 1:16:32 PM
Red Scholefield
Status: offline
It will be essentially the same as the present CellPro, which balances the cells by charging individually rather than discharging them all to the same level. It will just handle more cells and enable you to charge two 5S or less packs simultaneously.
Red S.
(in reply to RC David)
       Post #: 3
RE: FMA Announcing Cellpro 10s Charger - 11/21/2007 3:43:05 PM
Khatsalano
Status: offline
That is exactly what I've been looking for. I love the CellPro 4S I have right now but wanted a 10A high-capacity charger for larger packs so I don't have to wait as long. This is perfect. Am looking forward to its release.
- K
       Post #: 4
RE: FMA Announcing Cellpro 10s Charger - 11/22/2007 5:52:13 AM
RC David
Status: offline
Thanks Red.
ANY idea of approximate/estimated cost?
Dave D.
       Post #: 5
RE: FMA Announcing Cellpro 10s Charger - 11/22/2007 12:45:09 PM
Red Scholefield
Status: offline
SWAG - I would say in the US$ 150 range, but this is only a guess.
Red S.
       Post #: 6
RE: FMA Announcing Cellpro 10s Charger - 11/23/2007 3:40:05 AM
RC David
Status: offline
Thanks Red.
I'll be anxiously awaiting that charger.
Dave D.
       Post #: 7
RE: FMA Announcing Cellpro 10s Charger - 11/23/2007 6:12:19 PM
Josey Wales
Status: online
Red do you know if you will be able to charge 2 different chemistries at the same time. Example one A123 pack one one side and a Lipo on the other ?
Joe
       Post #: 8
RE: FMA Announcing Cellpro 10s Charger - 11/23/2007 7:13:47 PM
Red Scholefield
Status: offline
quote:
ORIGINAL: Josey Wales
I doubt if you can mix chemistries if it programs the same as the CellPro 4S.
Red S.
(in reply to Josey Wales)
       Post #: 9
RE: FMA Announcing Cellpro 10s Charger - 12/19/2007 11:09:39 PM
Josey Wales
Status: online
Red--Can you charge 2 packs at the same time at 10A ?
Joe
       Post #: 10
RE: FMA Announcing Cellpro 10s Charger - 12/20/2007 12:31:55 AM
Red Scholefield
Status: offline
Yes, 5 cell packs, max.
Red S.
       Post #: 11
RE: FMA Announcing Cellpro 10s Charger - 12/20/2007 12:57:02 AM
Josey Wales
Status: online
Excellent! Thanks
Joe
       Post #: 12
RE: FMA Announcing Cellpro 10s Charger - 12/29/2007 4:02:00 AM
Khatsalano
Status: offline
Pre Order is now available according to their website...
http://www.fmadirect.com/detail.htm?item=2247§ion=45
... but ... apparently it looks less cool than previously advertised. Bummer.
- K
       Post #: 13
RE: FMA Announcing Cellpro 10s Charger - 2/23/2008 3:20:01 AM
zayzay1
Status: offline
Has anybody received a shipping confirmation yet
(in reply to Khatsalano)
       Post #: 14
RE: FMA Announcing Cellpro 10s Charger - 2/23/2008 1:56:09 PM
Red Scholefield
Status: offline
The CellPro 10S has been under extensive testing by a number of beta testers (including the Battery Clinic) over the past 3 months to assure all the bugs were worked out. Yesterday we confirmed the last firmware revision that addressed an issue with charging 2 A123 packs. It appears now that all systems are go for a great charger that has passed critical testing by actual modelers. You will find its single button programming as easy as the very sucessful CellPro 4S. A great feature is that any time the unit is connected to your computer by way of the USB cable it will be checked for the latest firmware revision which can be downloaded directly to the unit if you chose to do so. Operation with the computer gives real time graphing of the charge process that can be saved for future reference. Normal operation however does not require that it be connected to your computer as all of the charge parameters can be changed as required directly from the one button programming feature. The entire charge process is displayed
