RE: Skymaster RTF F-4C install pictures
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Skymaster RTF F-4C install pictures
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Skymaster RTF F-4C install pictures - 1/11/2008 5:54 AM
avionics
Score: 100
Last Login: 11/7/2009
Status: offline
Hi Anton;
The NAV pictures are coming up beautiful. i look forwar flying this beauty.
Well Done Anton and the team.
Regards
Reza
Hide Signatures
(in reply to pilot tw)
       Post #: 26
RE: Skymaster RTF F-4C install pictures - 1/11/2008 9:01 AM
avionics
Score: 100
Status: offline
Hi Anton;
Can i just remind you that my F-4 is NAVY version and on the nose gear door i should have the RED< YELLOW, Green lights. please ask for NAVY version from the light manufacturer, (Please check Their site) http://www.details4scale.com./ .
Regards
Reza
Hide Signatures
       Post #: 27
RE: Skymaster RTF F-4C install pictures - 1/28/2008 9:57 PM
ianober
Score: 100
Status: offline
Anton, how are you operating the little outer gear door? I dont see any linkages or cylinders attachments.
Also do you offer the patterns for the wood pieces you made in this thread? Such as the main door mounts, the inner wing rib mount for the door cylinder and such?
< Message edited by ianober -- 1/28/2008 11:26 PM >
_____________________________
Global Jet Club Demo Team
Hide Signatures
       Post #: 28
RE: Skymaster RTF F-4C install pictures - 2/20/2008 6:50 PM
Kmarks
Score: 100
Last Login: 11/8/2009
Status: offline
Hello All,
I am building the SkyMaster F4 Jolly Rogers and I am at the point of installing the hardware into fuse. After trail balance it seems that this bird is tail heavy.
Have others found this jet to be tail heavy, if so how much weight was needed in the nose??
By the way, I cut intake duct work to move turbine forward, and placed all batteries, fuel pump, ECU, and air actuaters in front area. Batteries are in the nose.
Kevin
< Message edited by Kmarks -- 2/20/2008 7:06 PM >
Hide Signatures
(in reply to avionics)
       Post #: 29
RE: Skymaster RTF F-4C install pictures - 2/20/2008 7:46 PM
ianober
Score: 100
Status: offline
Kevin, post some pics of your install if you can, I am doing a hardware install as well and am interested in seeing your layout. I have heard that these are indeed pretty tail heavy and will requires nose weight. I am putting an Olympus in the one I am building for a customer but did not cut the ducting although the engine is pretty much as far forward as I can make it.
Hide Signatures
(in reply to Kmarks)
       Post #: 30
RE: Skymaster RTF F-4C install pictures - 2/21/2008 1:06 AM
yeahbaby
Score: 100
Status: offline
Bro'!!!
very exciting to hear about the olympus install. got any pix you can share?
Adil had mentioned previously that the engine bay area was large enough to handle the beast. That would be my engine of choice for this large bird assuming you could carry 160 oz of gas to feed the fire breather. might have to add a functional centerline to bring up the total fuel capacity. Just a guess tho'
cheerz
evoJet Booster Factory Pilot
Hide Signatures
(in reply to ianober)
       Post #: 31
RE: Skymaster RTF F-4C install pictures - 2/21/2008 4:04 AM
f106jax
Score: 100
Status: offline
Hey Buck,
A couple of days ago I measured the capacity of the tanks supplied by SM. The forward tank is 80 oz. and each of the main tanks 56 oz., UAT 4 oz., total 196 oz.
Mike
Mike
Hide Signatures
(in reply to yeahbaby)
       Post #: 32
RE: Skymaster RTF F-4C install pictures - 2/21/2008 5:05 AM
ianober
Score: 100
Status: offline
Her you go Buck. I am thinking about cutting the ducting more and moving the beast all the way up to the next former.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to f106jax)
       Post #: 33
RE: Skymaster RTF F-4C install pictures - 2/21/2008 5:39 AM
yeahbaby
Score: 100
Status: offline
SAAAAAAA WEEEEEEEEETTTTTTTTTAAAAAAAAAAAHHHHHHHHH
quote:
ORIGINAL: f106jax
Hey Buck,
Mike
Hide Signatures
       Post #: 34
RE: Skymaster RTF F-4C install pictures - 2/21/2008 5:46 AM
yeahbaby
Score: 100
Status: offline
heck yeah bro'!!!! chop off the intake and slide her forward.
U might want to paint the lower fuse from 1/2 of the motor to the aft former with a couple layers of heat shield or some sort of 1/2 shell bypass etc.. that ol' girl gets hot as hell when she's running and is at it's hottest when it's at idle. minimal air flow around the motor etc.
I didn't realize the amount of space in the engine bay very encouraging to say the least!!!
good luck with the build and first flights etc. the Olympus is gonna make her dance.
cheerz
quote:
ORIGINAL: ianober
Hide Signatures
       Post #: 35
RE: Skymaster RTF F-4C install pictures - 2/28/2008 5:04 AM
Da ROOK
Score: 100
Status: offline
HI Guys,
Here is my install. With this setup I have 3 Nimh batteries in the nose, 2 4200 mah 5 cell for RX and a 6cell 3200mah supplied by jetcat for ECU and mine came out slightly nose heavy. I think I am at 280. This is only static CG and Have not maidened the jet yet. I guess we will find out at Buttonwillow...YEAH>>>>.
Also you can see where my pipes ended up. I am hoping they have enough downtthurst and dont fry the UNDERTAIL...
I believe my batteries weight around 3 pounds.
Hope it helps.
Jason
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 36
RE: Skymaster RTF F-4C install pictures - 2/28/2008 5:38 AM
Ehab
Score: 100
Last Login: 9/12/2009
Status: offline
quote:
ORIGINAL: ianober
Looking great Ian....Cut that ducting as much as you can and leave room for a FOD screen. We will be using the three batteries, so keep the turbine battery till the end, for the balance.
(I may have the engines for the other one, Will keep you posted)
Regards, E. " Smoking Sam"
The Truth is out there, Seek it!!
Hide Signatures
       Post #: 37
RE: Skymaster RTF F-4C install pictures - 2/28/2008 5:58 AM
ianober
Score: 100
Status: offline
Cool Ehab, I am just putting along at other stuff so no worries!!
Hide Signatures
(in reply to Ehab)
       Post #: 38
RE: Skymaster RTF F-4C install pictures - 2/28/2008 6:19 AM
propsareforboats
Score: 100
Last Login: 7/8/2009
Status: offline
I installed a C-arf Lightning duct, a Tam pipe and moved everything way forward, had to make a new inlet ducting and move forward fuel tank partially into forward part of fuse.
CG came out at 300mm with the JC P-180, works nice and runs very cool.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 39
RE: Skymaster RTF F-4C install pictures - 2/28/2008 6:49 AM
Ehab
Score: 100
Status: offline
Good pics!
Ian, what do you think? Full bypass? I have the bypass from my lightning and we can have Tam make us a special pipe per our design.
Hide Signatures
(in reply to propsareforboats)
       Post #: 40
RE: Skymaster RTF F-4C install pictures - 3/18/2008 4:56 AM
alex2003
Score: 100
Last Login: 10/26/2009
Status: online
Hi all i'm building my F4c and all is good...I'm looking to install the cockpit but it looks to be to BIG..... About 10mm to each way..... Do you have to trim of some from both sides.... Not gona be easy..... Any sugestions would be nice i hate to cut it up if not needed.....
Please help....
Thanks Alex
Hide Signatures
(in reply to Ehab)
       Post #: 41
RE: Skymaster RTF F-4C install pictures - 3/18/2008 6:13 PM
ianober
Score: 100
Status: offline
The bypass would help Ehab since the airlines for the gear are underneath the turbine, but I was planning on putting a sheet of SS all under the turbine to protect the air hose. The only thing I am concerned about with a full bypass is that monster filling up all the bypass and choking down the airflow cause the Oly is so big. Plus, it may not fit into the bypass you have.
Hide Signatures
(in reply to alex2003)
       Post #: 42
RE: Skymaster RTF F-4C install pictures - 3/18/2008 8:48 PM
Ehab
Score: 100
Status: offline
The bypass I have was designed to fit the Oly beast, so it should be no problem if we decide to do it. I beleive in full bypass when ever possible.
Hide Signatures
       Post #: 43
RE: Skymaster RTF F-4C install pictures - 3/18/2008 9:07 PM
ianober
Score: 100
Status: offline
Well if it was made for it then I don't see any reason not to use it then buddy. Its up to you.
Hide Signatures
(in reply to Ehab)
       Post #: 44
RE: Skymaster RTF F-4C install pictures - 3/28/2008 3:16 PM
avionics
Score: 100
Status: offline
Hi everyone;
I am fitting my turbine P-160 in to my F-4. can i ask the ones with F-4 experience to have a look at the pictures and let me know if the location of the Turbine looks ok. I have pushed it as forward as possible but the tail cone distance makes me a bit worried.
thanks
Reza
Click for fullsize
Hide Signatures
       Post #: 45
RE: Skymaster RTF F-4C install pictures - 3/28/2008 3:25 PM
avionics
Score: 100
Status: offline
quote:
ORIGINAL: avionics
Hi everyone;
thanks
Reza
My other picture was not uploaded here it is the tail cone section picture
Reza
Click for fullsize
Hide Signatures
       Post #: 46
RE: Skymaster RTF F-4C install pictures - 3/28/2008 5:39 PM
ianober
Score: 100
Status: offline
Do you have a FOD screen on your turbine? Thats the only thing I would be worried about is not being able to put a FOD screen on.
Hide Signatures
       Post #: 47
RE: Skymaster RTF F-4C install pictures - 3/28/2008 6:37 PM
Rider-60
Score: 100
Status: online
Reza,
I would be more concerned about not getting enough (or not at all in this case!) bypassed air, you need to cut the inlet to allow that. Otherwise the engine will run very hot.
Hide Signatures
       Post #: 48
RE: Skymaster RTF F-4C install pictures - 3/28/2008 6:41 PM
avionics
Score: 100
Status: offline
No i havent put the FOD and yes the by pass air flow is another concern but how about the ehaust gas is there a psossibility that some of it comes out of the tail cone in to the fuse?.
Reza
Hide Signatures
       Post #: 49
RE: Skymaster RTF F-4C install pictures - 3/28/2008 6:55 PM
ianober
Score: 100
Status: offline
I think your fine on the back end but you could move the turbine back a little more and open up the top half of the inlet duct to get some bypass air.
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.094RCU1
