BaldEagel
Joined: 10/12/2005 From: Wychling, Kent, UNITED KINGDOM Status: offline
Dave Thanks for the information its usefull to know of other configerations. I thought the 2.1 was lighter than the 2x2 with a bigger wing area, I must of misunderstood all the blurb when they brought this out, do you know what the weight difference is? Interesting that the Spin 99 gets hotter, as you say this may be because of the ducted fan drawing more amps, what sort of amp draw is it compared too the 2x2? What would you do with hindsight about the side thrust, would you build it in, or use a mix on the Tx? I would appretiate your comments. Mike
_____________________________
No matter what anyone says 100% is the maximum you can get.
