RE: The Tango 40 ARF from Hangar 9
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: The Tango 40 ARF from Hangar 9
Page: <<   < prev  1 2 [3] 4 5 6 7 8   next >   >>
Login
RE: The Tango 40 ARF from Hangar 9 - 1/27/2008 1:42:19 AM
platinumjason
Status: offline
quote:
ORIGINAL: The Toolman
Hey, I've ask in 3 different places on 2 different forums about the angle of my engine an still haven't got any answer from somebody that actually has one to ck.
I don't see anywhere for the rubber bands to go either, I don't even have any rubber bands with my plane. I don't know where they come up with that.
Ronnie
Yes indeed seems Im not the only noticing this issues I really dont see anywhere for rubberbands nor rubberbands included for that fact. Anyone know?
_____________________________
Team Losi LST w/ LRP .28
WHH Manta Ray
(in reply to The Toolman)
       Post #: 51
RE: The Tango 40 ARF from Hangar 9 - 1/27/2008 1:54:13 AM
The Toolman
Status: offline
If yer going glow, the wood plate holds the tank in anyway. Piss on the phantom rubber bands.
Does your engine look like it is tilted up just a tad?
Ron
Ron B.
AMA-862729 PB-2718
(in reply to platinumjason)
       Post #: 52
RE: The Tango 40 ARF from Hangar 9 - 1/27/2008 3:32:08 AM
platinumjason
Status: offline
Motor looks level to me. Its a Tower Hobbies .46.
WHH Manta Ray
       Post #: 53
RE: The Tango 40 ARF from Hangar 9 - 1/27/2008 3:43:55 AM
The Toolman
Status: offline
Yea, mine looks like it is tipped up a 1/2 or 1 degree.
Ron
Ron B.
AMA-862729 PB-2718
       Post #: 54
RE: The Tango 40 ARF from Hangar 9 - 1/27/2008 4:53:03 AM
jdkxtreme
Status: offline
Anyone have a magnum 4 stroke in there plane?
       Post #: 55
RE: The Tango 40 ARF from Hangar 9 - 1/27/2008 5:44:09 PM
jdkxtreme
Status: offline
I am gonna try to ask another question..Has anyone ran into a problem with the screws that hold the motor mount on too long?Also did anyone put any kind of pilot in there bird?
(in reply to jdkxtreme)
       Post #: 56
RE: The Tango 40 ARF from Hangar 9 - 1/28/2008 2:16:29 AM
The Toolman
Status: offline
I cut the screws off, and no pilot.... What would he do anyway, the planes RC. LOL
Ron
Ron B.
AMA-862729 PB-2718
       Post #: 57
RE: The Tango 40 ARF from Hangar 9 - 1/29/2008 5:41:36 PM
RXRCER
Status: offline
JDK, I'm using the Magnum 70 four stroke. Plane flies so-so. Not the most versatile plane I've ever owned, wouldn't own another one, but the Magnum has plenty of power.
       Post #: 58
RE: The Tango 40 ARF from Hangar 9 - 1/29/2008 5:44:14 PM
RXRCER
Status: offline
And one other thing ALL of you that are complaing about "no rubberbands" to hold the tank in place. Pack foam around it and forget about it! Next thing you'll want radial treads on the wheels....YEESH!
(in reply to RXRCER)
       Post #: 59
RE: The Tango 40 ARF from Hangar 9 - 1/29/2008 5:52:03 PM
The Toolman
Status: offline
[quotNext thing you'll want radial treads on the wheelse][/quote]
Tell ya what, they could sure get rid of those heavy azz wheels an tires an put the foamies on it, I did......
Ron
Ron B.
AMA-862729 PB-2718
       Post #: 60
RE: The Tango 40 ARF from Hangar 9 - 2/2/2008 12:47:28 AM
PointMagu
Status: offline
Well, I've wanted one of these since I first saw it online. I finally found a slightly damaged one on eBAY and invested $60. on it.
Other than 3 crushed ribs, (easily repaired) and a little replacement covering the Tango should be as good as new.
I'm curious about comments made regarding the planes performance. I would think that a smaller airframe like this would be a "hack" flyer...something to toss into the trunk and have fun with...not serious aerobatics and the like.
It's nice to have something inexpensive, fairly nice looking and easy to whip around other than more sophisticated designs involving more inve$tment. I can live with all the neg's mentioned as I have other aircraft that DO perform the way I want them to. Expectations there are naturally, quite different.
I see the Tango for what I can get from it, (fun) not what the marketing department at Hanger 9 might extol it to be. Guess that would be nice though, huh?
I usually tinker, modify, adapt and recover ARF's...but not this one. I was looking for a fun plane and I think I've found it. I'll let y'all know.
Ed, might be a great review subject in an upcoming RCR!
PM
< Message edited by PointMagu -- 2/2/2008 4:20:53 PM >
Ah yes, snakes in the cockpit....
       Post #: 61
RE: The Tango 40 ARF from Hangar 9 - 2/7/2008 1:30:00 AM
boogermancan
Status: offline
i have fun with mine and no rubber bands i used some foam in there to hold he tank
some time''s one must putt finger in the prop to see how bad it will hurt!
Club Saito Member #544
(in reply to PointMagu)
       Post #: 62
RE: The Tango 40 ARF from Hangar 9 - 2/7/2008 11:55:52 PM
Ed_Moorman
Status: offline
Hey Pt Mugu, the wife got me a Tango and a second OS .55AX for Christmas, so it will be in my column soon. I plan on wringing it out and also fixing the roll due to rudder.
Before that I have a JBA .56 and a Goldberg Wild Stik that I just started flying.
I also just finished an Ultra Stick 60/SK 90 to replace the one I snapped the whole tail off of. It wasn't pretty. Came down on hard surface and splattered. All I could do was throttle back and watch.
This weekend I'll be testing a Lanier Stinger 40/Saito .72. The Stinger was only $80 at Tower-too good to pass up. I think it'll need bigger ailerons-3/4" is pretty small.
Ed Moorman, AMA 553, KD4QBM, Revver Bro #156
R/C Report Magazine, Fun Aerobatics Column
(in reply to boogermancan)
       Post #: 63
RE: The Tango 40 ARF from Hangar 9 - 2/8/2008 12:46:28 AM
PointMagu
Status: offline
SUPER! The 55AX looks to be a sweet engine. I have an Ultra Stick 60 with a ST 90 haulin' it around.
I have an SK50 NIB that I was considering mounting on the Tango. Since it's a long stroke, I figure the torque to be a better way to go than pure rpm's. What do you think?
Here's a shot of my US60. I recovered it as I really hate stock ARF finishes, lol...
PM
Click to see fullsize image.
Click for fullsize
(in reply to Ed_Moorman)
       Post #: 64
RE: The Tango 40 ARF from Hangar 9 - 2/17/2008 3:21:09 AM
jdkxtreme
Status: offline
What servos are you guys using in the wings?
