Phelansa
Joined: 7/9/2006 From: PretoriaGauteng, SOUTH AFRICA Status: offline
Crash, we are saying the same thing in different words. I cannot possibly agree with you more about the "Quality" of the packs one uses. I for one only use "Enerland" cells. Enerlands are also fitter to ThunderPower, Hyperion, TrackPower.... etc etc. As this is an electrical motor we are talking about here, the key word here is Power. The batteries ability to deliver power is a derived from 2 things. Its mah rating, and its C Rating. So yes, the one can substitute for the other. Make no mistake though. It takes BOTH to specify the correct battery for the application. Again, Power is the operative word here (W=VxI). When you lower the voltage the motor will consume more current to perform the same amount of work. The higher the voltage, the more efficient the motor. That is unfortunately a law of physics.
_____________________________
DF03-MM 4600, RS4 MT MM4600, Mayhem ST. Lama V4, HB Cool, BeltCp, TRex 450 and next...... ESmart!
