themadmax
TX, USA Status: offline
Jeez!...you guys make this sound so scientifically difficult! With the fuel tank empty, measure back from the leading edge 1/3rd the chord...that's your "safe" balance point. 1/4 chord, the safest. Most RC Aircraft are nose heavy, to begin with, and once you add 6-8 oz of fuel. or whatever, 3"- 4" forward of the CG, they just become more nose heavy. I've only seen one a/c in 30 years of flying that had a tail-heavy problem. A Nose-heavy condition only adds to the dynamic stability of the a/c while detracting from the instability that makes an a/c more aerobatic. The further aft you move the balance point, the better for aerobatics...to a point. Too far aft and a stall becomes irreversible Those of you considering putting your servos at the tail, shouldn't. It increases the pitch stabaility. (Not good for aerobatics) and creates CG problems for what?...now you've got long servo leads, (GLITCH!@#), another connection to go bad...what was the good point, again? If in doubt as to where stuff should go, build the airplane to a point where you can bolt on the wing and the engine. Then put the servos and battery such that your balance point is between 1/3 - 1/4 chord. The covering, cowl, wheels won't change things much and you can always move the battery out to the end of the engine mount, worst case lol KISS, (Keep it simple ------!)
< Message edited by themadmax -- 11/26/2007 5:53:04 AM >
