wphilb
NY, USA Status: offline
The bands I made out of tape, the auto detail kind, seemed to be the right color and easy to use. I crammed everything I could get in front of the full cockpit, and it balanced without weight (if memory serves, I will pull it down tonight and check) the OBG and battery adds some forward weight, as does the twin engine. The aileron bellcrank set-up also adds weight. I think the rudder and elevator servos are right behind the seat but everything else is up front. If I did add weight it wasn't much. I've seen weight boxes built on the firewall in these planes. Whit
