YS 110FZ problem question,,
Tower Hobbies
Logged in as Guest
  Printable Version
RCGF 26cc Rear Induction Gasoline Model Airplane Engine
Seller:  jewillis2
Details:   $224.88   |  12/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> YS 110FZ problem question,,
Page: [1]
Login
YS 110FZ problem question,, - 11/24/2007 4:08:53 AM
jongurley
Status: offline
Hye Troy I just bought a YS 110FZ from a guy, I put it on a GP geebee,, and started it for the first time today, I have a check valve, filter all the stuff is plumbed correct,, well I can start it up and it idles great and the transistion is fine,till about 3/4 throttle, as the rpms jump up past(ballpark figure) 7-8 thousand, all of a sudden I can see the fuel go out of the intake line going from the front of the engine the the clunk line on the tank,, , and the motor sags and I can let off the throttle back to below say half throttle and the fuel will suddenly shoot back in to the intake line,,, but like I said I can transistion good but when it shoots up to high rpm it acts like it sucks the intake line dry,,, (and it almost looks like it is sucking the fuel back in the tank ,very quickly),, but then I can drop the throttle back down to 3/4 throttle or below, and it fuel returns back in the line,, thanks for any info troy or anyone,, thanks,
_____________________________
"Practice, confidence and arrogance makes you a better pilot, few can use these to the best of their ability" JONG
       Post #: 1
RE: YS 110FZ problem question,, - 11/24/2007 4:50:48 PM
Troy Newman
Status: offline
Is the tank under pressure when you shut it down?
My guess is no.
If the tank was holding pressure then there is no way for the fuel to go toward the tank in that line.
Your plumbing is not correct or the tank is not holding pressure (has a leak).
From the symptom I would say right off hand your check valve is not installed correctly...the proper direction is to allow air from engine to the tank, and block the air from coming out of the tank.
Next thing is are you using a YS check valve. There are other varieties on the market that use a small ball bearing and a little spring. These take more pressure to close off. So when the tank is not up to pressue it will take longer to get up to pressure.
Next is to fill the tank with fuel, then plug up the check valve side and pump more fuel into the tank. This will build pressure in the tank. See if its leaking? It could be leaking past the check valve even though the check valve is installed with the proper direction. Check this. If the tank system will not hold pressure then it will not work.
The engine does NOT suck any fuel above 2000-2500rpm. It is force fed fuel above 2000-2500rpm by the pressure in the tank. The way it works is the tank is under about 6-8psi. The carb gives a little suck on the regulator and the plunger opens allowing fuel to flow past it as its under pressure. When the pressur ein the line gets to equal the pressure in the tank the fuel stops flowing and the spring will close the plunger. The only line that has any suction at all is the line from the Regulator to the Carb. This only happens when it is at the right spot in the rotation cycle and it is just a lower pressure than the 8psi in the tank. I doubt it is ever negative pressure...The enigne never really sucks fuel at all.
Now if the check valve is installed backward, or missing then the fuel in the pressure line will move toward the engines when its not on its pressure push cycle, and the when the pressure line is pushing pressure into the tank the check valve will stop it from going to the tank and act like the tank is already up to pressure.
Another option is the check vlave could be sticking from gummed up fuel and oil. You can pump raw fuel through them and this will usually un-stick a gummed up one.
Troy Newman
Team YS
(in reply to jongurley)
       Post #: 2
RE: YS 110FZ problem question,, - 11/24/2007 11:40:11 PM
jongurley
Status: offline
Thanks Troy I will check all of these things tommorow,, something I forgot to mention, I have the engine mounted inverted,, and lets say I turn it over to prime it, it runs ABUNCH of fuel out of the exhaust pipe,, almost like the fuel line hooked to a muffler like on a saito or whatever, but it just runs out of the exhaust,, for a second until I start it,, ????????????????????????
(in reply to Troy Newman)
       Post #: 3
RE: YS 110FZ problem question,, - 11/25/2007 3:35:58 AM
Troy Newman
Status: offline
Plumbing is not correct. Double check to make sure the check valve is attached in the proper line and in the proper direction. Then make sure the plumbing matches the diagram. I think you likely have plumbing messed up...they just don't dump fuel like that..
If the regulator was staying open all the time the fuel would run from the carb not the muffler.
The enigne should likely not need any prime to get it started...maybe if its been sitting for a long time....
Inverted mounting has no effect on these engines. If they are upright you might be able to run them a little richer at idle that if they are inverted that is the only difference upright to inverted mounting.
Troy Newman
Team YS
       Post #: 4
RE: YS 110FZ problem question,, - 11/25/2007 3:39:58 PM
jongurley
Status: offline
I will check it out and let you know Troy, thanks,
       Post #: 5
RE: YS 110FZ problem question,, - 11/26/2007 11:30:24 PM
jongurley
Status: offline
Looking at the front of the motor, there are two nipples stuck straight up ,,, one is pressure and one is intake,, which one is what, I can turn the prop over and the one on the right, looking at the front of the engine pumps fuel out,,,
       Post #: 6
RE: YS 110FZ problem question,, - 11/27/2007 12:50:56 AM
Troy Newman
Status: offline
The nipple on the exhaust side of the engine is fuel IN...the nipple on the Needle Valve side of the engine is Pressure back to the tank.
The one on needle valve side toward the rear of the pressure line out...(inline with the cam gear) connects to the nipple that is back at the Needle Valve assembly.
The main thin is the connections up front. The one on the exhaust side is fuel IN the one on the needle side is pressure out.
The check vlave installs with the arrow point toward the tank. This allows pressure into the tank and stops the pressure from coming back toward the engine.
here is the manual that came with the engine
http://www.yspartsandservice.com/pdf/FZ110.pdf
Troy Newman
Team YS
< Message edited by Troy Newman -- 11/27/2007 12:51:53 AM >
       Post #: 7
RE: YS 110FZ problem question,, - 11/27/2007 2:57:32 PM
Tommy_Gun
Status: offline
Also,
The notch cut into the check valve to indicate direction of flow can be deceiving.
The notch has a short end and a long end. The long end should be directed toward the tank.
In any event, I always blow thru them to do a manual check of the proper direction.
Yeeeeahhh seee.
Say hello to my leetle fren.
       Post #: 8
RE: YS 110FZ problem question,, - 11/27/2007 3:28:42 PM
jongurley
Status: offline
I had the lines crossed guys,, so maybe that will fix the problem, I am using a new Perry check valve,, it seems to work fine doing the blow through test so I will try it for now,, and maybe now it will crank up and run right tonight,,
(in reply to Tommy_Gun)
       Post #: 9
RE: YS 110FZ problem question,, - 11/27/2007 9:52:33 PM
Troy Newman
Status: offline
You will want to use the YS check valve....The Perry may work, But the YS check have a fairly low pressure to close. many of the check valves on the market have a ball bearing in them and it takes too much pressure to close them off. This doesn't allow for the engine to build pressure.
This could also be your problem. I have no experience with the perry...but if it doesn't close fast enough (blow test is not good enough) then it will likley not close until pressure gets higher in the tank. Since the pressure ina YS builds slowly you need the YS style of check valve.
Troy Newman
Team YS
       Post #: 10
RE: YS 110FZ problem question,, - 12/3/2007 12:20:59 PM
jongurley
Status: offline
Hey Troy, I got the YS running decent,(had the fuel lines crossed), the only problem now is the low - mid range,, When I start it up , even with the glow heat on the engine, when I try to transistion from idle on up ,, it will fall on its face, I will quickly back it back down to idle and it will catch up and idle decent,, but I if it stays at a low idle to long it will cut off,,, ,,,,,, , , then I can crank it back,,, I can fly it around fine, but when I back it down to a high idle to keep it running it is to high of a idle,, but when I back it down on final approach to a slow idle to land it will cut off by the time it gets to the runway,, just wondering,,, to me it sounds lean on the low it,, it doesn't really burble when you advance the throttle after you start it,, it will just almost cutoff, then I can quickly bring it back down to idle and it will sound fine,, but the high end(if I can get the throttle to take that far) sounds good,,,, anyway, thanks for any advice Troy
< Message edited by jongurley -- 12/3/2007 12:21:21 PM >
       Post #: 11
RE: YS 110FZ problem question,, - 12/3/2007 5:49:06 PM
Troy Newman
Status: offline
Yes likely lean on the low end... Maybe the regulator is a little lean too.
Regulator is set at 4000rpm....surging up and down is lean, and slowly loading up is rich. Regulator works the same as the HS needle In (CW) is lean and out (CCW)is Rich.
Then drop it into a low idle....2000rpm or as close as you can get, but try to get it less than 2400 at least...goal is 2000rpm....If it drops to a higher rpm then will slowly settle to the lower rpm its lean. If it drops to the 2000rpm right away and then surges up and down its lean. If it drops to an idle then slowly loads up and quits then its rich. The air bleed screw on the carb is OUT (CCW) for Leaner and IN (CW) for richer.
A tell tail sign of too lean on the regulator or low end is a sudden quit on throttle up. a ZiiiiiiiiiiP! and then it catches and goes or just dies. If its rich on the low end or regulator is will chuuuuug-chuggg-chuc-chug-chug and eventually clean out and throttle up. rarely will it stumble on a throttle up when its rich...it will just take a while to clean out. The quick stumble is a sign of too lean.
Troy Newman
Team YS
       Post #: 12
RE: YS 110FZ problem question,, - 12/3/2007 6:17:01 PM
jongurley
Status: offline
Thanks Troy I will play with it tonight,, thanks, I will let you know,,
       Post #: 13
RE: YS 110FZ problem question,, - 12/4/2007 3:44:27 AM
mjfrederick
Status: offline
Could also still be the perry check valve. If it leans out on the low end, you could be losing pressure in the tank when the throttle is brought back down.
mjfrederick AMA 275874 NSRCA 4134
Maybe the Dingo ate your baby
       Post #: 14
RE: YS 110FZ problem question,, - 12/5/2007 2:02:50 AM
jongurley
Status: offline
OK guys got back to the tuning today,, I have g
