reg seyup please help
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Smart-Fly (Quest Engineering) Support Forum >> reg seyup please help
Page: [1]
Login
reg seyup please help - 11/24/2007 2:42:23 PM
SJS
Status: offline
I am building a 35% yak and I have most of my equiptment. I plan on using 2 rec's with 2- 7.4v 4400 m/a li-ion batts for redundency. I plan on splitting the load between the 2 rec's as follos; rec 1 has 1- 5925 servo)throttle), 2 - 5955 servos (left ail)and 1 - 8711 servo(left elev). The other rec has 4 - 5955 (rt ail and rudder)servos and 1 - 8711 servo(rt elev). The aileron servos will be programmed for center woth the hitec programmer. I also have a 7.4v 2200 li-ion bat for the igniton for a da100. Will your standard regs w/ failsafe provide enough amperage for each receiver, based on my setup? Also, which reg for the ignition?
SJS
       Post #: 1
RE: reg seyup please help - 11/24/2007 6:50:26 PM
rrritchey
Status: offline
Hi SJS,
The Standard Adj Regulators will work just fine in this application. We have flown 35% planes on a single regulator. The Ignition Reg should work for your ignition.
Please let me know if you have any other questions.
_____________________________
Robert Ritchey
Owner, Smart-Fly
(in reply to SJS)
       Post #: 2
RE: reg seyup please help - 11/28/2007 12:00:43 AM
hooker53
Status: offline
SJS, That sounds like a good set-up your planning. All you need now is a power expander. After you first use one, you will never fly a 30% or larger without one!! Good luck. Hooker53
Scratch it till it bleeds Convert it till it chokes
(in reply to rrritchey)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
