Joined: 12/25/2002 From: Thurso, UNITED KINGDOM Status: offline
Hi I am about tp start building my Zeque 70 ( birthday present) and the first thing that struck me was that the engine is hard mounted to the fuselage. Has anyone built and flown this beast and if so does hard mounting work out OK or have people fitted Vibration dampening mounts if so which one? Also any other hints and tips about the build would be most welcome.
Hi I got mine from Noel Barratt Models in Cork Ireland. But surely there must be someone closer to you that stocks the plane. I am sure Noel would sell you one but the carriage would be a killer.
Joined: 9/8/2005 From: hampshire, UNITED KINGDOM Status: offline
HI, they are a great model,had one for months and just sold it on,hard mounting works fine,use the hatori header and pipe and she is very quiet,done three gallons and no vibration issue at all,hope you enjoy.
Joined: 5/28/2005 From: London, UNITED KINGDOM Status: offline
Ive got one too and theres no way im selling mine! Great plane, really locks in well, snaps are crisp and it slows down really well for landings.
I soft mounted my YS63 with iso bobbins and use the hattori short pipe. tettra fuel tank mounted over the c of g and used a flightpower evo20 7.4v lipo through a powerbox digi switch (regulator)
Putting this plane together is super easy and quick, I like the way the firewall is marked out and the engine mount predrilled.
Bad points...the first and really agrevating one is the quality of the covering, mine was peeling off before it even flew so I went about sealingevery edge before hand and the undercarriage legs are a little too soft. A nice carbon set would be a good upgrade.
< Message edited by jaycey -- 11/25/2007 6:28:53 PM >
I used a product from Flair called balsaloc, I lifted the edges painted it on then ironed it down when dry, its been ok so far but it was a absolute pain to do and took days!!
Ask around you may find a better product or methos for doing it. But whatever you do...do something as it is a shame to see a lovely looking plane look tatty after a short time.
pictures...
You might make out Mr Suzuki's signature on the wing, he was the man who designed the Oxai 2 metre Zeque and who was in the Japanese team at the World champs
< Message edited by jaycey -- 11/25/2007 8:20:15 PM >
hi mike, i just got a bit bored with the mode!,but flew the model a lot!,and it is a great model to fly!,you will love it .model was bought by a fellow club member and is still going strong now!!!.
Joined: 5/28/2006 From: HK, HONG KONG Status: offline
Mine is using hard mount coming from the kit without any problems, the vibration from YS61 is not strong and also the plane is constructed strong enough to stand with this normal vibration.
The tail of this little pattern ship is so powerful. I needed to dial in much more exp than the recommended data by Suzuki and am still taking time to get used to it. Snap is extremely crisp and precise which is the most impressive feature of this little toy and I had so much fun to play around with snap maneuvers. The only complaint happens on the elevator linkage system which uses a U shape metal stuff to link up two elevator halves. I found it is a bit flexible to hold the another halve tightly. I am going to modify it to see if there is any improvement on precision aspect.
< Message edited by happyfly2006 -- 12/2/2007 3:51:52 PM >
