RE: Royal Kits    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Hangar 9 Piper J-3 Cub 40 ARF / Saito 90 twin - RTF
Seller:  Hill202
Details:   $450.00   |  5/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Royal Kits
Page: <<   < prev  41 42 43 44 45 46 47 [48] 49 50   next >   >>
Login
RE: Royal Kits - 8/8/2012 10:33 AM
scale only 4 me
Score: 319
Last Login: 5/24/2013
Status: offline
Hide Signatures
(in reply to smithcreek)
       Post #: 1176
RE: Royal Kits - 8/8/2012 1:05 PM
smithcreek
Score: 159
Status: offline
Here's the other plane's maiden. I apologize for my poor video skills and constant chatting, I was a bit hyped up after my maiden.
_____________________________
For a kit you are, and to a kit you shall return.
Hide Signatures
(in reply to scale only 4 me)
       Post #: 1177
RE: Royal Kits - 8/13/2012 8:22 AM
fabfal
Score: 100
Status: offline
Many thanks. Some suggestion for the retracts? Centuryjet has got them. I have already used the Centurion series but it seems to be heavy fot that size. Do you  know some other supplier that can satisfy both scale and weight? Better air or mechanic retract?
Hide Signatures
(in reply to hattend)
       Post #: 1178
RE: Royal Kits - 8/26/2012 12:02 AM
maddingo
Score: 100
Last Login: 10/5/2012
Status: offline
Hey guys,
Im bashing through a Royal .60 size corsair. Ive got a hold of some great robinaire retracts ready to install. Does anyone have plans or manual that I can read on how some retracts were to be installed before I just make the install process up.
Thanks guys.
Dingo
Hide Signatures
(in reply to fabfal)
       Post #: 1179
RE: Royal Kits - 9/19/2012 4:08 PM
Aldo Rebsamen
Score: 100
Last Login: 4/2/2013
Status: offline
Hi
Congratulation to those beautiful P26. And how surprisingly well they fly.
I have a Marutaka kit I bought in the 80's. The fuse is assambled but I put it aside. After watching your video I think I will relaunch the build.
Can you please give some technical details, like:
- down thrust used (if any)
- right thrust used
- CG
- angle between wing and elevator (I dont know the English expression, in Germin it is called EWD)
- did you build in any washout in the outer wing panels?
- did you make any building changes in respect to the original drawing? if so please give me some details.
- did you use the landing gear setup shown on the plan?
- any advice for my build you would like to give to me.
Thank you for your help.
Best Regards
Aldo Rebsamen
Hide Signatures
(in reply to maddingo)
       Post #: 1180
RE: Royal Kits - 9/20/2012 1:19 PM
smithcreek
Score: 159
Status: offline
quote:
ORIGINAL: Aldo Rebsamen
- right thrust used
- CG
Do you still have the plans? If not I can look the numbers up, but we built them to plans except for the landing gear described below. All the important angles, right and down thrust, wing and stab incidence, cg, all according to plans. My friend did build washout into his wing, I did not and don't see any need to after flying.
We used the landing gear as shown on the plans but moved them in towards the fuse. On the plans the main wire is anchored in a block by the root rib on the outer panel and is bent 90 degrees to go down to the wheel at the 2nd rib. We just switched that around so it's anchored by the 2nd rib and goes down at the first. This was to move the gear in to a more scale position, but I'm sure it will lead to more nose overs. Best advice is to keep it light behind the cg. If any of the blocks that came with the kit are heavy make some new ones. Also, IMO flaps are a must. If you have not seen the build thread I did it is Royal Build Thread. A lot of the pictures are gone, but I can repost them if you have any specific questions. Good luck with your build!
Hide Signatures
(in reply to Aldo Rebsamen)
       Post #: 1181
RE: Royal Kits - 9/23/2012 11:15 PM
TLH101
Score: 175
Status: offline
Here is my fiberglass copy of a Royal B-17F, Fort Alamo II, nearly ready for it's first flights. Just a few cosmetic details and it will be ready. Weighs 12lb 3oz, with 4, 1000kv motors on 2, 3s 5000mah batteries.
I posted a few pics of the kit earlier in this thread, back in June of last year. Well it's finaly fiknished. You can see the build thread here: http://www.rcgroups.com/forums/showthread.php?t=1417449
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Terry
"Old Fart" in training. (not to be an R/Cer, but to be an "Old Fart")
Hide Signatures
(in reply to Builder2010)
       Post #: 1182
RE: Royal Kits - 9/24/2012 3:50 AM
I-fly-any-and-all
Score: 100
Last Login: 5/20/2013
Status: offline
Awesome plane!
I went on ebay last winter and purchased 4 used o.s. .20 four stroke engines for mine.
I paid $70
$65
$110
and $170.
Then I found a seller on ebay that sells the bearings and piston ring for $25 so I have four rebuilt engines.
I've been busy moving into an apartment, and getting ready for college so I haven't touched mine.
Hide Signatures
(in reply to TLH101)
       Post #: 1183
RE: Royal Kits - 9/24/2012 4:32 AM
Builder2010
Score: 100
Last Login: 4/23/2013
Status: offline
On our B-17 we used four, OS FS-26s, 4-stroke and the plane was a bit underpowered according to the owner and pilot, Mike Hunt. The second problem we had was getting them to idle having been mounted inverted. These were older OS's and didn't have carburetor adjustments that let use get them running slow. It therefore was landing very hot. If I were to build it again, I would have tried to use electrics with a sound system duplicating four Wright radials. That would have been cool. The plane, I understand is now sold to a guy who has it hanging in his office. The young man in the picture is my grandson, Alex. He's now 11 and turning into a fine model maker.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to I-fly-any-and-all)
       Post #: 1184
RE: Royal Kits - 9/24/2012 5:43 AM
scale dail
Score: 115
Last Login: 5/23/2013
Status: offline
Since we are talking B-17's right now, I found a group that flies B-17 the same size as my newly rebuilt Royal B-17. I am the only one that runs glow power. I need the ultra reliability of my 4-OS.15CVA's to keep up with more than 10 other electric models. Many spectators are suprized as I taxi back with the group that my B-17 has 4 mufflers! Go Royal!
http://www.youtube.com/watch?v=Acdq53fmYSE&list=UU1OdIFMBSeprlfBkG5KzBGQ&index=1&feature=plcp
Click for fullsize
Click for fullsize
It does NOT have to be GIANT to be scale!
Hide Signatures
       Post #: 1185
RE: Royal Kits - 9/24/2012 4:00 PM
Firepower R/C
Score: 110
Last Login: 5/16/2013
Status: offline
Oh my gosh... that picture is amazing. It looks like full scale Bombers gathering after takeoff into formation!
Firepower R/C
Saving un-loved R/C airplanes around the world
Hide Signatures
(in reply to scale dail)
       Post #: 1186
RE: Royal Kits - 10/8/2012 10:57 PM
scale dail
Score: 115
Status: offline
Our B-17 squadron visited the Wings over Chino event. The Royal B-17 is the one with the flaps down .
Click for fullsize
< Message edited by scale dail -- 10/10/2012 2:09 AM >
Hide Signatures
(in reply to Firepower R/C)
       Post #: 1187
RE: Royal Kits - 10/9/2012 9:00 AM
fabfal
Score: 100
Status: offline
At the beginning, yesterday night, I thought they were the real B17. Only this morning I read your comment on the thread and realized they are models. It's really fantastic. Never seen something like this. Only the engine noise is missing!!!!!. My compliments!!
Fabrizio
Hide Signatures
       Post #: 1188
RE: Royal Kits - 10/29/2012 7:41 PM
Walther
Score: 105
Status: offline
Does anyone have the plans for the royal 1/2A P-51 that they could copy for me?
Hide Signatures
(in reply to Riddle4U)
       Post #: 1189
RE: Royal Kits - 11/16/2012 9:49 PM
smithcreek
Score: 159
Status: offline
If anyone is interested I have an extra P-26 short kit. Same parts I cnc router cut for our group build that I posted pictures and a video of on the previous page. This kit was cut back when we started the project for a guy that bailed out at the start, never even picked up his parts. It includes copied plans, all the cnc router cut balsa and lite ply ribs, formers, fuse parts, etc., all the band saw cut balsa blocks, fin and rudder post, stab trailing edge, elevator leading edges. The only cut parts it is missing are some belly pan formers, they are on the plans so you can cut them. Most of the parts have a little fuzz on the edges that comes of with a touch of sandpaper.
It does not include spars, and sheeting. There are not many sticks needed, a couple for the fuse, a couple for the ailerons. Also, you can buy the fiberglass parts from Fiberglass Specialties, or we can work out a deal where you would put a fairly substantial deposit on the molds we have and make you own, which I will return when you return the molds. If anyone is interested, pm me, it's $40 shipped in the lower 48, that's less that the wood and plans alone. I have the instruction manual scanned and can send an electronic copy.
Hide Signatures
(in reply to Walther)
       Post #: 1190
RE: Royal Kits - 11/16/2012 9:54 PM
P-Y
Score: 105
Status: offline
At that price, it's a bargain. Too bad I live abroad!
Hobbistar 60 / SIG SE (†) / TF Cessna 310 / OMP ProYak / TF Spitfire MKIX (†) / Parkzone Radian / Royal C-47
Hide Signatures
       Post #: 1191
RE: Royal Kits - 11/16/2012 9:55 PM
Deaner777
Score: 100
Last Login: 3/25/2013
Status: offline
What is the wingspan on that plane? I might be interested.
Hide Signatures
(in reply to P-Y)
       Post #: 1192
RE: Royal Kits - 11/16/2012 10:03 PM
smithcreek
Score: 159
Status: offline
Wingspan is 67". Just to be clear, this is just the plans and wood parts described above, no plastic or fiberglass, no wire for landing gear. If you are interested PM, don't reply on this thread please. I'm signing off for the evening and will check pms in the morning.
Hide Signatures
(in reply to Deaner777)
       Post #: 1193
RE: Royal Kits - 11/17/2012 1:23 PM
smithcreek
Score: 159
Status: offline
parts are sold thanks. Good to know they won't go to waste.
Hide Signatures
       Post #: 1194
RE: Royal Kits - 11/17/2012 3:01 PM
Sharpeye22
Score: 120
Status: offline
 I am not nearly the craftsman you are but I shall enjoy building and flying the Peeshooter.  I have a Hobbyking version of it that I picked up from a friend but it is so heavy from his repairers after his manny crashes that it is almost unflyable.  I will build this one as light as possible.
thanks for the opportunity.
Larry
Saito Club #692
Hide Signatures
       Post #: 1195
RE: Royal Kits - 11/28/2012 8:52 AM
fabfal
Score: 100
Status: offline
Hi Guys
I'm getting started with a royal AT6 TEXAN from plan. I'm looking for an advice about the retracts. First: pneumatic or mechanical? Searching on the web I've found only Centuryjets that produces a gear for AT6 royal 1/7 scale. Robart provides only the gear for Top Flite or 1/6 scale. Is there anybody the has already built this model and can give me some suggestion?
Fabrizio
Hide Signatures
(in reply to Sharpeye22)
       Post #: 1196
RE: Royal Kits - 11/28/2012 4:30 PM
Chad Veich
Score: 265
Status: offline
quote:
ORIGINAL: fabfal
Hi Guys
Fabrizio
I would think that pretty much any standard 90 degree retract could be made to work Fabrizio. The Robart gear for the TF airplane would probably be fine except that you would have to adjust the length of the struts to suit your slightly larger model. I'm not aware of anybody making a retract specifically for 1/7 scale AT-6 models except for the afforementioned Century Jet Models. My only advice would be to do your research on CJM before deciding whether to purchase from them or not. I fly nothing but pneumatic retracts and love them, don't do mechanicals at all. There may be some electric retracts available as well that would work but, again, do your research first as their are many problems being reported with just about all that are currently available.
Hide Signatures
       Post #: 1197
RE: Royal Kits - 11/28/2012 5:25 PM
fabfal
Score: 100
Status: offline
I thank you very much. On the original plan the retracts are mechanical. Considering the weight of the model (4Kg) and the simplicity of mounting  maybe it's better to follow the plan. I found something ( For corsair FU) of the right dimension onli to  be bended as per plan. CJM solution is very expensive(350$) and uses centurion cylinders that are very heavy for the model. Robart has got one pneumatic solution but is 1/8 scale and should be anyway modified.I have personally experimented the electrical solution ( sonic) but it is very delicate . If you do not land perfectly on the tarmac and you touch on the grass, you have to change anytime some spare to the gear!!!
Hide Signatures
(in reply to Chad Veich)
       Post #: 1198
RE: Royal Kits - 11/29/2012 8:03 PM
amilcar
Score: 100
Last Login: 5/7/2013
Status: offline
do you make aluminum cowl for the stagerwing royal ?if so how much will cost me? plans also for this plane?
thanks,
Hide Signatures
       Post #: 1199
RE: Royal Kits - 11/29/2012 9:10 PM
Chad Veich
Score: 265
Status: offline
quote:
ORIGINAL: fabfal
A Corsair has rotating retracts while the Texan does not. Are you certain what you have found is suitable for the AT-6?
Hide Signatures
       Post #: 1200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.937RCU1
