boiling tires..    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> boiling tires..
Page: [1]
Login
boiling tires.. - 11/25/2007 7:47 AM
ttoks
Score: 100
Last Login: 5/24/2013
Status: offline
well i have to say this hasnt worked to well, in an attempt to un-glue a set of tires, i today boiled them for an hour, and still the glue is stuck, i don't know what else to try the heat is what breaks down the glue and there was plenty of heat, all i used was CA glue for the tires, nothing fancy to glue the tires on there, i'll try baking them but if an hour in 100 degree C water doesnt do it i don't know what will without melting the rims..
_____________________________
"If everything feels under control, you''re not going fast enough"-Mario Andreti.
Hide Signatures
       Post #: 1
RE: boiling tires.. - 11/25/2007 7:54 AM
ericem
Score: 100
Last Login: 4/17/2010
Status: offline
Was the water boiling?
Hide Signatures
(in reply to ttoks)
       Post #: 2
RE: boiling tires.. - 11/25/2007 7:55 AM
ttoks
Score: 100
Status: offline
yeah, i had the heat on high the whole time.
Hide Signatures
(in reply to ericem)
       Post #: 3
RE: boiling tires.. - 11/25/2007 7:56 AM
DriftingDragon
Score: 100
Last Login: 4/28/2013
Status: offline
try low temp hot knife
and pry the tire off as it unglues
| AXIAL SCX10| Slash MAMBA MONSTER |DF-03 |
Hide Signatures
(in reply to ttoks)
       Post #: 4
RE: boiling tires.. - 11/25/2007 8:16 AM
ttoks
Score: 100
Status: offline
just tried baking them for 20 minutes at 120 degrees C (about 250 F) and nothing, not hot enough? it's starting to test my patients as it's taken almost two hours so far and i haven't gotten one tire off of the rim, only thing i can think of is the glue.
Hide Signatures
(in reply to DriftingDragon)
       Post #: 5
RE: boiling tires.. - 11/25/2007 8:20 AM
Danju
Score: 100
Last Login: 5/18/2012
Status: offline
i tried using a razor once..takes forever and if you dont do it right, youll cut the tire instead of seperating the tire from the rim...be patient and maybe youll get some done.
Hide Signatures
(in reply to ttoks)
       Post #: 6
RE: boiling tires.. - 11/25/2007 8:23 AM
ttoks
Score: 100
Status: offline
i'm just leaving it for the day, it's frustrated me enough for one day.
Hide Signatures
(in reply to Danju)
       Post #: 7
RE: boiling tires.. - 11/25/2007 8:26 AM
89ram
Score: 100
Last Login: 12/11/2007
Status: offline
preheat the oven to 350 degrees. turn it off then put in your tires. wait for 15 minutes, then take them out. use gloves. squeeze the tires and they should pop off of the beads. it worked for me. hope this helps.
big block revo basher............. got nitro?
Hide Signatures
(in reply to Danju)
       Post #: 8
RE: boiling tires.. - 11/25/2007 8:28 AM
NitroBurn1
Score: 100
Last Login: 4/25/2011
Status: offline
Did you try pulling the tire while its still hot?
Hide Signatures
(in reply to ttoks)
       Post #: 9
Danju
Score: 100
Status: offline
are you trying to take the tires off the rims from your revo? i found that traxxas, from factory, put a honkin' load of CA on the tires and i can see the glue dried along the rim..they put a bunch...
Hide Signatures
(in reply to ttoks)
       Post #: 10
RE: boiling tires.. - 11/25/2007 8:41 AM
ttoks
Score: 100
Status: offline
no, badlands off of standard MT rims.
Hide Signatures
(in reply to Danju)
       Post #: 11
RE: boiling tires.. - 11/25/2007 9:20 AM
KRO
Score: 115
Last Login: 5/18/2013
Status: offline
Baking them has always worked for me , you do need to pull them off while its still hot though .
I just laid the tire on its side and pushed the bead off of the rim .
Ten SCTE , LST2 ,Micro SCT , Tekno 8ight T , RCSC8
B44 , Hyper 10SC , E-REVO , Micro DT , Tekno D8
Hide Signatures
(in reply to ttoks)
       Post #: 12
RE: boiling tires.. - 11/25/2007 9:42 AM
HerrSavage
Score: 318
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: 89ram
I used these instructions as a guidline once - well, almost.. I left the oven on for the whole time, and "just to be sure" made it 20 minutes instead of 15.. I melted two tires and rims...
So, in other words, I think the way 89ram described it is probably about right...
Be warned though, it'll stink up your kitchen for a day..
Nitro > stamp collecting, watching grass grow, cleaning room, etc.. > electric.
Hide Signatures
(in reply to 89ram)
       Post #: 13
RE: boiling tires.. - 11/25/2007 1:21 PM
The Winner
Score: 100
Last Login: 9/17/2010
Status: offline
just boil them in 100 c for 10 minutes and then with a lot of force with your hand pust the tire out!
Inferno ST-RR powered by Dynamite Platinum .28,Byron Fuels GEN2,Sanwa M11 DSSS,ACE DS1015&DS1313 Servos,Pro-line LPR wheels
Hide Signatures
(in reply to HerrSavage)
       Post #: 14
RE: boiling tires.. - 11/25/2007 1:46 PM
ttoks
Score: 100
Status: offline
yeah boiling water for an hour and it still ended up taking chunks out of the rubber to get one of them off of the rim, didn't destroy the tire but i'd rather have it left intact, i think i'll try the oven again tomorrow but go up to 160 instead of 120 C.
Hide Signatures
(in reply to The Winner)
       Post #: 15
RE: boiling tires.. - 11/26/2007 4:50 AM
89ram
Score: 100
Status: offline
just remember to shut off the oven when you put them in!
Hide Signatures
(in reply to ttoks)
       Post #: 16
RE: boiling tires.. - 11/27/2007 6:49 AM
jombo
Score: 100
Last Login: 3/12/2008
Status: offline
yup boiling and the oven did nothing for me either in the end i threw them out because the oven melted the rims and boiling them destroyed the rubber and ended up ripping through the tire. next time i will try the ca remover it is sold by zap i think and its a red color used it a couple of times when building planes but could'nt find it when i needed it. good luck
ka-chow
lst2, there is no substitute lst forums, ground pounders rc
Hide Signatures
(in reply to ttoks)
       Post #: 17
RE: boiling tires.. - 11/27/2007 11:42 PM
jatoracing33
Score: 106
Last Login: 4/2/2011
Status: offline
im guessing your rims have a finish on them right? if not or if you dont care about the finish then you could try acetone (spelling?)
Floods Brothers Represent
Hide Signatures
(in reply to jombo)
       Post #: 18
RE: boiling tires.. - 11/28/2007 5:50 AM
x5t1j
Score: 100
Last Login: 12/29/2010
Status: offline
Use a heat gun
Hide Signatures
(in reply to jatoracing33)
       Post #: 19
RE: boiling tires.. - 11/28/2007 11:30 AM
ttoks
Score: 100
Status: offline
i tried acetone, didn't work.. i ended up prying half of each tire off without damaging them to much to get the tape out of there ( it came unstuck from the tire and was unbalancing the wheels, thats why i needed to get the tires off).
Hide Signatures
(in reply to x5t1j)
       Post #: 20
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
