New plastic gasser    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Airboats >> New plastic gasser
Page: [1] 2 3   next >   >>
Login
New plastic gasser - 11/26/2007 12:41 AM
crispyspa
Score: 137
Last Login: 5/23/2013
Status: offline
After much contemplation....I decided to make another plastic hull airboat. This design has been borrowed from Hooty301 (with blessings) and his legendary, wall climbing "Kamakazee" airboat.
44" long 20" wide and 4" deep. A poulon Wood Shark (36cc) from a previous build will be used for power.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
After all is said and done, more is said than done.
Hide Signatures
       Post #: 1
RE: New plastic gasser - 11/26/2007 4:57 AM
89ram
Score: 100
Last Login: 12/11/2007
Status: offline
that looks pretty sweet! what sort of plastic are you using, and how are you gluing, adhereing, etc?
big block revo basher............. got nitro?
Hide Signatures
(in reply to crispyspa)
       Post #: 2
RE: New plastic gasser - 11/26/2007 6:37 AM
crispyspa
Score: 137
Status: offline
quote:
ORIGINAL: 89ram
Thanks!
I get the 1/8" ABS plastic in 4 x 8 sheets from a local company called Regal plastics . cost is around $40. I put it together using Methyl Ethyl Ketone, or MEK for short. It is a solvent normally used in painting (I think) but it melts the ABS quite readily. I also make a paste glue using the MEK and ABS scraps that is used for sealing the joints.
Weight as shown: 22 LBS. hoping to stay right around 25 LBS RTR, which will be about 10 LBS lighter than my last one. It may be heavy...but it's almost bullet proof.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to 89ram)
       Post #: 3
RE: New plastic gasser - 11/26/2007 9:37 PM
jasperrc
Score: 100
Last Login: 8/12/2011
Status: offline
Can't wait to see this one finished!
Jasper
Hide Signatures
       Post #: 4
RE: New plastic gasser - 11/27/2007 9:48 PM
crispyspa
Score: 137
Status: offline
Did a strength test and a float test today....I will need to close up the transom. There goes the cool design.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to jasperrc)
       Post #: 5
RE: New plastic gasser - 11/27/2007 10:09 PM
dadkins
Score: 104
Last Login: 5/21/2013
Status: offline
Floats a little low huh. If you keep it going - up on plane - no problemo.
Its a shame to change that nice hull.
Hide Signatures
       Post #: 6
RE: New plastic gasser - 11/28/2007 11:13 AM
crispyspa
Score: 137
Status: offline
quote:
ORIGINAL: dadkins
........I still have to add the cage, which will weigh around 3.5 LBS. yEEsh! I'll build the cage first, then close in the back if I need to.
Hide Signatures
(in reply to dadkins)
       Post #: 7
RE: New plastic gasser - 11/28/2007 1:46 PM
shaunmichaeljohnson
Score: 100
Last Login: 9/1/2010
Status: offline
yeah try it first
it is a really nice build and i'm planning an ABS boat some time in the future
maby i'll go with the kamakaze design too
if it doesent sink under the cage weight then give it a go because the water WILL clear out as soon as it moves.
shaun
rustler VXL all rpm''d
revo 3.3 electric conversion (under construction)
Hide Signatures
       Post #: 8
RE: New plastic gasser - 11/28/2007 3:52 PM
TERBObob
Score: 100
Last Login: 8/8/2009
Status: offline
Heck with closing her up ... living up in Onalsaka , that white stuff is soon to hit and stay . Keep her as is for the winter , and THEN modify if needed .
( snow runners are LOTS more fun that running on water - that is soon to be FROZEN )
"experienced " is just another way of saying that you already did all the mess ups and should know better now !
Hide Signatures
(in reply to shaunmichaeljohnson)
       Post #: 9
RE: New plastic gasser - 11/28/2007 5:41 PM
dadkins
Score: 104
Status: offline
Check out this cage - made of an old bike rim - aluminum - super light 1 lb at most. ok - Its ugly - but very functional .
Ok - it's not really a cage - but a rollbar !
Click for fullsize
< Message edited by dadkins -- 11/28/2007 5:43 PM >
Hide Signatures
       Post #: 10
RE: New plastic gasser - 11/28/2007 6:12 PM
asmithnc
Score: 100
Last Login: 5/22/2013
Status: offline
Looks like another winner from the ol' Crispy's workshop. Keep us posted on the build.
Member of the RCAA
Custom Rudder Works
Hide Signatures
       Post #: 11
RE: New plastic gasser - 11/29/2007 9:11 AM
hooty301
Score: 100
Last Login: 5/14/2013
Status: offline
Sweet work!
As far as the floating issue goes, not sure how the extra weight from the cage is going to effect it but I think it should be fine.
Id definatly try it first before you close it in.
Hide Signatures
(in reply to asmithnc)
       Post #: 12
RE: New plastic gasser - 11/29/2007 10:52 AM
crispyspa
Score: 137
Status: offline
Thanks guys!
I have formulated a plan to keep the cage weight to a minimum. I think 1/4 x 1/4 square and 1/4 x 1/2 Aluminum will be the building material. It'll be much like this other cage, but with only 1 hoop and not as much bracing. BTW the one in the pic is 4 1/2 LBS.
Click for fullsize
Hide Signatures
(in reply to hooty301)
       Post #: 13
RE: New plastic gasser - 11/29/2007 6:08 PM
dadkins
Score: 104
Status: offline
Those must be solid sqare metal rods used to build that. Cuz MAN that seems heavy, does that include the gas tank?
Your motor doesn't mount to the cage does it?
Hide Signatures
       Post #: 14
RE: New plastic gasser - 11/30/2007 11:22 AM
crispyspa
Score: 137
Status: offline
quote:
ORIGINAL: dadkins
Yea...solid aluminum. It is heavy, (including gas tank) but you have to remember it was made to house an 18" prop. It was also made to withstand severe abuse.
Hide Signatures
       Post #: 15
RE: New plastic gasser - 12/9/2007 7:46 AM
crispyspa
Score: 137
Status: offline
quote:
ORIGINAL: crispyspa
Thanks guys!
The problem with plans...? Sometimes they go right out the porthole..LOL The way I beat on my boats, I figure I may as well add the second hoop at the cost of adding 1 LB.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 16
RE: New plastic gasser - 12/9/2007 12:58 PM
vamp131
Score: 100
Last Login: 5/4/2012
Status: offline
it it not a little top heavy how does it run in water than nice job looks very fast films be great
Hide Signatures
       Post #: 17
RE: New plastic gasser - 12/9/2007 4:56 PM
RS 38-40
Score: 100
Last Login: 5/26/2013
Status: offline
Crispyspa is there any chance you could post a couple pictures of your cage roller ? I for one would like to see it . Maybe in another thread . Us DIYers you know
Hide Signatures
(in reply to vamp131)
       Post #: 18
RE: New plastic gasser - 12/10/2007 1:46 AM
crispyspa
Score: 137
Status: offline
quote:
ORIGINAL: RS 38-40
Done. new thread started.
did some more work, but I ran out of aluminum stock. I'll have to finish later.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to RS 38-40)
       Post #: 19
RE: New plastic gasser - 12/10/2007 2:18 AM
L_J_Engineering
Score: 100
Last Login: 4/2/2008
Status: offline
wheres the rudders
Hide Signatures
       Post #: 20
RE: New plastic gasser - 12/10/2007 2:20 AM
crispyspa
Score: 137
Status: offline
quote:
ORIGINAL: L_J_Engineering
wheres the rudders
LOL It's not finished yet.
Hide Signatures
(in reply to L_J_Engineering)
       Post #: 21
RE: New plastic gasser - 12/10/2007 9:41 PM
jasperrc
Score: 100
Status: offline
Looks great crispy!
Jasper
Hide Signatures
       Post #: 22
RE: New plastic gasser - 12/30/2007 3:45 AM
crispyspa
Score: 137
Status: offline
got a little more done, and another strength test. LOL Oh ya...L_J_ ...here's the rudders. EDIT: weight (without me on there) 24 Lbs.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by crispyspa -- 12/30/2007 3:46 AM >
Hide Signatures
       Post #: 23
RE: New plastic gasser - 12/30/2007 6:58 PM
TERBObob
Score: 100
Status: offline
VERY nice ...
( seems someone is VERY handy with working with aluminum )
Now , get those foot prints mopped up and get out there and get us some video ---- LOL
Not sure about water ... but that boat SURE does look like a perfect contender for the snow .
Hide Signatures
       Post #: 24
RE: New plastic gasser - 12/31/2007 4:31 AM
crispyspa
Score: 137
Status: offline
Thank you for the complement Terbo.
As far as water running.....it'll probably be like all the others, trouble turning right. WHY? I dunno. Never figured that out.
It is DONE. Except for the maiden voyage. Got done late (like 1/2 hr ago) so I didn't get the chance to run it. Finished RTR weight is 27 Lbs 3 Oz. (including full tank of gas). Tomorrow I will try to get out and shoot the vid.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to TERBObob)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.875RCU1
