RE: G & L Hobbies Extra 300 build thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: G & L Hobbies Extra 300 build thread
Page: <<   < prev  1 2 3 [4] 5 6 7   next >   >>
Login
RE: G & L Hobbies Extra 300 build thread - 1/1/2008 7:31:45 AM
smullis
Status: offline
I like the scheme of the of the paint on the plane. Good lines and looks fast even sitting on the ground I bet.Any color would look sharp.Just go with your instincts and have a ball.
S Mullis
(in reply to lrglnman)
       Post #: 76
RE: G & L Hobbies Extra 300 build thread - 1/2/2008 1:06:44 AM
lrglnman
Status: offline
Lets take a look at some pics !
[image][/image]
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
The Large Lineman
James Smith
(in reply to smullis)
       Post #: 77
RE: G & L Hobbies Extra 300 build thread - 1/2/2008 1:21:47 AM
lrglnman
Status: offline
Pic 1 is how the servo will mount in the wing. I cut 2- 1/4"x2" pine blocks. Recess them in the wing to give the servo something to mount to. I used 5 min epoxy.
Pic 2 is the rudder servo plate.I placed the plate as low as possible so to keep the pull pull wires stright. I will then build a plate for the 2 elevator servos directly behind the rudder plate ,only slightly higher so the push rods just clear the rudder servo. I think 2 standard servos will work fine on the elevator halves.
Pic 3 shows everything primmed. I used a 2 part auto primer.
Pic 4,5, & 6 shows a close up shot of the detail on this plane. As you can see when the primer is applied , you can see all the imperfections . But don't worry. Nearly all fiberglass type kits will have this. The folks @ G & L Hobbies do a super job of fiberglassing and there was not much puttying to do .
Pic 7,8, & 9 Shows all the glass puttied up and ready to sand off. I went to the auto parts store and bought a tube of spot putty which works great for filling in all the small pin holes.
The Large Lineman
James Smith
       Post #: 78
RE: G & L Hobbies Extra 300 build thread - 1/2/2008 1:25:54 AM
lrglnman
Status: offline
[image][/image]
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
The Large Lineman
James Smith
       Post #: 79
RE: G & L Hobbies Extra 300 build thread - 1/2/2008 1:34:39 AM
lrglnman
Status: offline
Pic 1 Shows the fire wall bolted up and ready for the engine. do you rember the fire wall ring I installed in the fusealage? Well the outer firewall bolts to that. Now by doing it this way I have access to the inside of the fusealage if i ever need to make adjustments or repairs.
Pic 2 shows the final dusting of primer.
Pic 3 -6 shows how I made the removable canopy. alot of room for adding details if you want to. I wonder who is gonna pilot this bird? I installed 2 small wood dowels in front and am thinking of a magnent to keep it in place. Is this a good idea?
The Large Lineman
James Smith
       Post #: 80
RE: G & L Hobbies Extra 300 build thread - 1/2/2008 2:36:13 AM
Gray Beard
Status: offline
Magnets, good idea. You can get small rare earth magnets from radio shack or hardware stores. Just don't go magnet to magnet, use magnet to A metal screw. If not you will think you screwed down your hatch when you try to remove it.
Don't ask how I know that.
If drinking and driving are illegal, then why do bars have parking lots???
       Post #: 81
RE: G & L Hobbies Extra 300 build thread - 1/6/2008 6:27:31 AM
lrglnman
Status: offline
Today, I finished up on the servo and tank platform instilation. I placed the 8oz tank right on the cg so I won't have a ballance issue as the tank empties. I should be able to move it back and forth till I get it fine tuned for best ballance. I also screwed the platform in so if iI need to remove it ,6 screws and its out. I thought about doing the servos that way but thought the extra ridgedness from the epoxy may make a better instilation. I also started doing some covering. I am doing a blue and white theme and started with the white. any suggestions on the bottom. What is the very best visiable scheme to do . If you look back a few post you will see the colors I am doing. I went with the Western Austrailia dot com theme. A real fast looking plane. but the bottom is got me on hold.
The Large Lineman
James Smith
(in reply to Gray Beard)
       Post #: 82
RE: G & L Hobbies Extra 300 build thread - 1/6/2008 10:50:04 PM
lrglnman
Status: offline
[image][/image]
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
The Large Lineman
James Smith
       Post #: 83
RE: G & L Hobbies Extra 300 build thread - 1/6/2008 11:29:47 PM
Xtremerc
Status: offline
LOOKIN GOOD............
       Post #: 84
RE: G & L Hobbies Extra 300 build thread - 1/7/2008 2:04:24 AM
lrglnman
Status: offline
Pic 1 is how I installed the servo trays and tank tray.
Pic 2 is the posterboard templates of the top side of my wing. from these I will cut out the covering.
Pic 3 the white goes on first.
Pic 4 Completed top side of wing minus trim.
The Large Lineman
James Smith
(in reply to Xtremerc)
       Post #: 85
RE: G & L Hobbies Extra 300 build thread - 1/9/2008 3:52:28 AM
Xtremerc
Status: offline
C YA AT THE MEETING THURSDAY NIGHT......
       Post #: 86
RE: G & L Hobbies Extra 300 build thread - 1/9/2008 10:43:11 PM
lrglnman
Status: offline
whoot !!!!!!! Dale is back !!!!!!!!!
The Large Lineman
James Smith
       Post #: 87
RE: G & L Hobbies Extra 300 build thread - 1/10/2008 3:26:59 AM
lrglnman
Status: offline
Well I got to do some covering tonight. One word I HATE COVERING!!!!!!!!! Both wings are finnished and Am going to start the fusealage this weekend hopefully will have pics posted soon.
The Large Lineman
James Smith
