RE: G & L Hobbies Extra 300 build thread (Full Version)
All Forums >> [RC Airplanes] >> Kit Building
Message
lrglnman -> RE: G & L Hobbies Extra 300 build thread (1/21/2008 6:21:48 AM)
[image][/image]
lrglnman -> RE: G & L Hobbies Extra 300 build thread (1/21/2008 6:22:58 AM)
[image][/image]
lrglnman -> RE: G & L Hobbies Extra 300 build thread (1/21/2008 6:26:22 AM)
PIC 1is how I finnished off the elevator wire tubes . mixed up some 30 min epoxy with micro balloons real thick and formed it to my liking.
Pic2 shows the result.
On my next one i think I will make a small epoxy mold to do this that way I can make it look real nice. I like the way it came out .could have been netter though.
lrglnman -> RE: G & L Hobbies Extra 300 build thread (1/21/2008 6:27:56 AM)
[image][/image]
lrglnman -> RE: G & L Hobbies Extra 300 build thread (1/21/2008 6:32:40 AM)
I got around to doing some painting this weekend !!!!! the end is near!!!!!!![:D]
Xtremerc -> RE: G & L Hobbies Extra 300 build thread (1/22/2008 3:54:00 AM)
How long before the first flight??????
Budro -> RE: G & L Hobbies Extra 300 build thread (1/22/2008 8:00:13 PM)
Hey Large Lineman, looks like you have built a million of these in the past. I think building fiberglass kits are one faster and two lighter than regular built up construction with balsa only plus you have a little more freedom when painting. I saw you have been talking to flyinmike. He knows his smoke when it comes to building either way. Greg also has a nice 40 size Miss Los Angles which I built about eight years ago. A really nice flyer and good looking to boot. Well keep up the good work and keep us posted on the build.
Buddy Qualls alias Budro[8D]
Gray Beard -> RE: G & L Hobbies Extra 300 build thread (1/22/2008 10:00:09 PM)
What paint are you using?? Looks good. I'm going to give the Klass Kote A try. A friend has been using it and gives it very high marks. I looked it up on the net and for the price it should paint the plane for me.
lrglnman -> RE: G & L Hobbies Extra 300 build thread (1/23/2008 1:00:40 AM)
Thanks for the words Buddy.
Greybeard I used the ultracoat brand paint in the spray cans. Suppose to match up with the covering but it lacks a bit there. Overall I am satisfied with the results. I learned one thing though , don't use newspaper the mask off anything . I sprayed the white first and let it dry 2 days before I masked it off to do the blue. Well this type paint "skins over" to touching strength in a few hours. so I didn't leave the newspaper on no longer than that .Well I peeled it off and got a nice line except where the paper touched the white I now have print on the white part. but its no big deal I thing I can fix it. I never heard of the paint you talked about but on my next plane I will use it. sounds like it is very glo resistant. THe paint I used does take along time to cure . about a week or so .
Gray Beard -> RE: G & L Hobbies Extra 300 build thread (1/23/2008 2:08:36 AM)
That's why I asked. I can build and cover with the best of them but when I have to paint it looks like A kid in grade school did it. I use the top flight and Ultra paints often and discovered if I didn't use there primer then it tended to peel with the masking tape. www.klasskote.com and it's A pretty good site and A lot of info on there paint plus the prices. As A 50/50 mix you don't have to buy too much though. Be ware, I had two colors in mind but my wife looked at the site and now it's going to be different then what is in my minds eye. I'm color blind so I don't really care as long as I can see it in the air.
My hope is this paint will make me look better then what I have been putting out over the years. I really do stink at painting.
lrglnman -> RE: G & L Hobbies Extra 300 build thread (1/23/2008 2:24:55 AM)
I used a 2 part primer that I got from the auto paint store. The stuff is great not cheep but goes on and sands nice. It is a epoxy type primer that works with nearly all paint. seams like I paint better than covering. I guess I need to move where you are and we build planes together :-) .I have nt figured out how I am going to do the checkers on the cowel heck I may leave them off and put them on the rudder only.
BCTENN -> RE: G & L Hobbies Extra 300 build thread (1/25/2008 10:56:51 AM)
See G&L Hobbies he knows about a paint mask to do the checkers on the cowl. BobC.
lrglnman -> RE: G & L Hobbies Extra 300 build thread (1/26/2008 3:39:00 AM)
Will do Bob.
I have done a little bit of changes. I smoked the canopy with Pactra spray tint in a small rattle can. results are nice. I took off the striping on the wings and have decided to got to the auto parts store for some pinstriping. And I have the Zenoah g20 on order should be here by saturday. I hope I have not messed up with it. If I get it I will have some pics to post tomorrow.
lrglnman -> RE: G & L Hobbies Extra 300 build thread (1/27/2008 6:02:32 AM)
[image][/image]
lrglnman -> RE: G & L Hobbies Extra 300 build thread (1/27/2008 6:24:38 AM)
Pic 1 Almost there !!!!
Pic 2 Mounting the Zenoah G20
Pic 3 G20 stripped of carb and muffler in cowl . As you can see the prop adapter lacks 1/2 inch making it to the proper end of the cowl. I think I will trim 5/8 inch from the cowl so it will slide up the fusealage further. I could make stand offs but I thing cutting the cowl will be a better idea.
Pic 4,5, and 6 G20 with Carb and muffler attached.
Pic 7 shows the throttle. Here is a great topic on some different ways folks are setting up their throttle. http://www.rcuniverse.com/forum/m_5083207/tm.htm . Here is another thread, http://www.rcuniverse.com/forum/m_6814982/tm.htm
Pic 8 is another shot of the G20
Here is a thread on different exaust systems, http://www.rcuniverse.com/forum/m_6835998/tm.htm
smullis -> RE: G & L Hobbies Extra 300 build thread (1/27/2008 7:57:22 AM)
James: Are you gonna use your stock muffler or are you going to use a aftermarket? If you go with a inverted wrap around you will need standoffs so don't cut that cowl up yet unless you use a straight style side exhaust.Think your gonna have enough power.[:D] you should be able to do 3D all day long with that plane and engine combo.
VP UCRCS
S Mullis
Gray Beard -> RE: G & L Hobbies Extra 300 build thread (1/27/2008 3:42:16 PM)
I would go along with the stand offs. It will give you room for change as things go along.
Great looking flying machine!!
lrglnman -> RE: G & L Hobbies Extra 300 build thread (1/27/2008 6:14:31 PM)
Thanks guys I just happen to have a nice mill in my shop and I will make me some stand offs. I got to keep the plane 9 lbs of less for great performance. I think I will be real close.
Xtremerc -> RE: G & L Hobbies Extra 300 build thread (2/2/2008 11:48:42 PM)
Well hope your filling better this weather suxs warm ,cold ,warm, cold.
I was going to go out today but had to cut a 35 ft tree that up rooted during the storm the other night.
Guess you guys are busy after the storms..
Oh yea i cut my first cores in a year and a half turned out good.........
Later Dale
lrglnman -> RE: G & L Hobbies Extra 300 build thread (2/3/2008 3:23:36 AM)
Great Dale! That hot wire cutter plan you gave me works great for cutting foam. I have been doing some practicing myself in my spare time. Dang cold messed up a good weekend of flying.[:(] Any how I have done some tinkering on the extra this afternoon. I mounted the throttle servo and the ignition box to the fire wall and I said to myself what would happen if I fired the Zenoah g20 up? So I put a 15-8 top flight prop on her and after experimenting a few min to get use to gas she fired up on the 3 flip!!!!!!!!![:D] . This little engine has alot of pull to her !!! It took my dad and myself to hold her back!!!! any way I hop to finnish her up this week and hope for a good day to try her out . I will post pics of how I did the firewall and the completed setup later.
[:D][:D][:D][:D][:D]
lrglnman -> RE: G & L Hobbies Extra 300 build thread (2/8/2008 3:24:55 AM)
[image][/image]
lrglnman -> RE: G & L Hobbies Extra 300 build thread (2/8/2008 3:30:28 AM)
Pic 1 Sullivan tail wheel . I really like this setup. It works fine and easy on the rudder
Pic 2 Beginning to mill out the standoffs for my engine. 3/4" aluminum
Pic 3 & 4 Shots of the finished stand offs. came out perfect with the cowl.
I am starting to plumb the servos and will post pics of that later as well of the way I mounted the motor, ignition,& throttle servo.
Xtremerc -> RE: G & L Hobbies Extra 300 build thread (2/9/2008 12:05:40 AM)
U DA MAN !!!!
lrglnman -> RE: G & L Hobbies Extra 300 build thread (2/9/2008 1:30:33 AM)
Making the stand offs was a challenge as i never used a metal lathe before. but I took my time and all is well. Had a good instructor giving me points.
Xtremerc -> RE: G & L Hobbies Extra 300 build thread (2/9/2008 3:03:20 AM)
NOT BURGESS ?
THAT COST YOU A BEER OR TWO......HEHE
Page: <<   < prev  1 2 3 4 [5] 6 7   next >   >>
Valid CSS!
SITE MAP!   : :   FORUM RULES
0.40625
