RE: G & L Hobbies Extra 300 build thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: G & L Hobbies Extra 300 build thread
Page: <<   < prev  1 2 3 4 5 [6] 7   next >   >>
Login
RE: G & L Hobbies Extra 300 build thread - 2/9/2008 2:47:37 PM
lrglnman
Status: offline
No mike dind't help. good ole trusty brother in law. he moved to Cookeville and lucky me stored his lathe in my shop .
_____________________________
The Large Lineman
James Smith
(in reply to Xtremerc)
       Post #: 126
RE: G & L Hobbies Extra 300 build thread - 2/14/2008 6:48:44 AM
KEITH RUSH
Status: offline
How is the elevator stabs put on? Are they on a tube? Also are you running a standard muffler, canistor muffler, or tuned pipe?
Keith
Keith Rush
(in reply to lrglnman)
       Post #: 127
RE: G & L Hobbies Extra 300 build thread - 2/15/2008 3:01:38 AM
lrglnman
Status: offline
Keith, The horizontal stab is a 2 piece sheeted stab joined together with epoxy and then a 1/4 oz fiberglass strip laid on the joint. On the fusealage is a reference line as to where the centerline of the stab should be. Before you glue the stab together use it to lay out your holes you are going to dremmel out later. an insedence meter is very helpful here to get it at 0 degrees. after you get both sides laid out you can take a dremmel tool and a sanding drum and cut out the area for the stab to slide into. after you have it cut out, epoxy 2 pieces of lite balsa on the underside of the cut outs so the stab has a place to rest on. slide the stab in and from there you can adjust it for proper angles and fit. when you are satisfied with the fit tack it down with some epoxy on the balsa blocks and let set up. then mix up some slow cure epoxy and micro balloons to a peanutbutter thickness and fill in the area around the stab . this sets the stab in for good. as for the muffler I plan on using the stock muffler.
The Large Lineman
James Smith
(in reply to KEITH RUSH)
       Post #: 128
RE: G & L Hobbies Extra 300 build thread - 2/15/2008 3:05:12 AM
lrglnman
Status: offline
here is a pic looking inside the fusealage.
Click to see fullsize image.
Click for fullsize
The Large Lineman
James Smith
       Post #: 129
RE: G & L Hobbies Extra 300 build thread - 2/15/2008 3:06:44 AM
lrglnman
Status: offline
As you can see i have used tubes for my 4-40 wires but I have since decided to install the servos on the outside .I was not happy with the way it was working for me so I made a change.
The Large Lineman
James Smith
       Post #: 130
RE: G & L Hobbies Extra 300 build thread - 2/23/2008 11:44:16 PM
lrglnman
Status: offline
Finally got around to some more work on the Extra
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
The Large Lineman
James Smith
       Post #: 131
RE: G & L Hobbies Extra 300 build thread - 2/23/2008 11:46:30 PM
lrglnman
Status: offline
Pic 1 shows the fuel dot for filling
Pic 2,3, and 4 showes how I cut up the cowl. I split it down the center on the bottom side so I can take it of and on super easy and you can't tell it
Pic 5 shows how I reworked the elevator servos.
The Large Lineman
James Smith
       Post #: 132
RE: G & L Hobbies Extra 300 build thread - 2/24/2008 4:10:34 AM
lrglnman
Status: offline
Here is a small video of my first test run with thr Zenoah g20 . IT is idleing very high and I need to adjust some more.
http://www.youtube.com/watch?v=okhjkv5iNnI
The Large Lineman
James Smith
       Post #: 133
RE: G & L Hobbies Extra 300 build thread - 2/24/2008 4:24:12 AM
lrglnman
Status: offline
While your at it check this out
http://www.youtube.com/watch?v=8B64L2a5uGI&feature=related
The Large Lineman
James Smith
       Post #: 134
RE: G & L Hobbies Extra 300 build thread - 2/24/2008 7:42:06 AM
KEITH RUSH
Status: offline
James,
Plane looks great and the G20 sounds awsome. Doesn't sound like the typical Zenoa. Sounded more like a glow and looks like it will have good power. Can't wait to see the vid of it flying.
Keith
Keith Rush
       Post #: 135
RE: G & L Hobbies Extra 300 build thread - 2/24/2008 1:57:55 PM
lrglnman
Status: offline
Ya know I thought the same thing. Man this little engine has alot of power. The lhs was out of switches and I need one for the kill switch for the engine. Also need a regulator cause I plan on using lipos for ignition and servos. I will post a better video later after I make some adjustments.
The Large Lineman
James Smith
       Post #: 136
RE: G & L Hobbies Extra 300 build thread - 3/9/2008 10:18:27 PM
lrglnman
Status: offline
I got to do some work on the extra 300 today.
here is some tack readings for the G20
http://www.rcuniverse.com/forum/m_7199409/anchors_7199409/mpage_1/key_/anchor/tm.htm#7199409
Nearly everything is complete with the plane except balancing . hope to have a video of flight soon. If anyone out there in cookeville has a digital camcorder let me know.
The Large Lineman
James Smith
       Post #: 137
RE: G & L Hobbies Extra 300 build thread - 3/10/2008 2:38:30 AM
Xtremerc
Status: offline
EX PREZ HAS ONE .CYA AT THE MEETING
       Post #: 138
RE: G & L Hobbies Extra 300 build thread - 3/15/2008 11:57:11 PM
lrglnman
Status: offline
[image][/image]
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
