blitzkrieg65
CA, USA Status: online
B Bullfrog, It plugs in but you have to make the plug, and everything all of the components have to be soldered onto the board, plus IC and including the Apple or shade lamp needs to be built. Now I don't want to step on Darkith, so if you object Darkith let me know? But I don't believe that he wants to get into the assembely business and I wouldn't mind doing it, for two reasons! One the circuit he has is outstanding you can program the tank for proprtional drive, or not you can remove the super spin or not more realistic! It has all of the same specs as Tamiya as far as hit range number of hits with and angles and so on. There is one differance on the number of hit you can log DBU can log or Death 1, 3, 5, 9, Tamiya is 3, 6, 9 I think you can do 5 hit on Tamya also but not sure? With the different hit settign is a faster or slower reload time to be able to fire! Larger tanks can take more hits say 9 and it takes them 9 seconds to reload! I like the DBU flexiblity beause you could ty this system in the furture to a should mounted Rocket louncher and with one hit you can kit him or he could get a couple of rockets off before someone takes him out! Also very cool with the DBU is a custom sound board that is preassebled but you have to solder the wiring on it, and you can load you own custom hit sounds and firing sounds, or it will default to the Heng long sound with the eception of the death sound I believe darkith has that programed on the main chip! I will try to take a couple of realy nice pics of mine tonight! The blitz
