LowFlyBye
TN, USA Status: offline
quote:
ORIGINAL: seemefly_1 you sure it isn't a piper pawnee this photo is very similar It is not a Pawnee. A Piper Pawnee has the same basic rounded tail feathers, center (fusalage) mounted landing gear, and wings as the PA18A-180 Supercub. The wing struts are just on the top side instead of the bottom and the tail is a little bigger. This bird has square off tail feathers, aft windows, squared off wingtips and a wide gear mount. Also notice the large flaps and how the wing struts are mounted less than half way out on the wing. The Pawnee has very short flaps with long ailerons and the struts mount nearly 2/3 out towards the end of the wing.
< Message edited by LowFlyBye -- 11/27/2007 5:32:51 PM >
_____________________________
To most people the sky is the limit. To a pilot the sky is home.
