How do you charge your LiPo batteries?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Helimax >> How do you charge your LiPo batteries?
Page: [1]
Login
How do you charge your LiPo batteries? - 11/26/2007 4:00:05 PM
MMatheny
Status: offline
I know you use a LiPo charger and hopefully a balancer - what I want to know is where do you charge them and what precautions do you take when charging - in the garage, do you use a LiPo charging bag, do you have a metal fireproof box you charge them in, brick fireplace, etc!
_____________________________
Mike
"Never use your shins as a blade tracking device" - Mike
       Post #: 1
RE: How do you charge your LiPo batteries? - 11/26/2007 6:05:02 PM
dreimer
Status: offline
I use an EFlite balance charger, and I put it away from anything that can catch on fire. Concrete floor, and concrete wall should protect anything else.
Aside from that, I also keep an eye on the charging process.
(in reply to MMatheny)
       Post #: 2
RE: How do you charge your LiPo batteries? - 11/26/2007 6:27:43 PM
HelisRule
Status: offline
Mike,
When I first got my LiPo I had read all the same horror stories that you've probably read. So I put the battery in a metal container, had my GP thermal probe on it and sat right there in my basement workshop next to the workbench, with a fire extinguisher on the floor next to me. While it was charging I worked on the heli or read the forums on my laptop to pass the time. I checked the temperature of the battery about every 10 minutes and it never gained a degree (in fact, sometimes it dropped depending on ambient temp). I also picked the battery up and looked it over several times during the charge to look for any sign of swelling - nada. The charge went fine, finished fine with no problems. I've charged it several times since then, and while I am much more relaxed about it, the only thing I've changed about the process is that I no longer put it in a metal container, but I am right there throughout the charge and I still check the temp occasionally. I also still have the fire extinguisher handy, and numerous metal containers are around that I could toss over it, but I'd more than likely use the fire extinguisher first.
I have a sheet of masonite on the top of my 4'x8' workbench that I could easily replace after a catastrophic LiPo failure. I doubt the LiPo fire would burn through that before I got it out, but if that was a danger I could push it onto the basement floor pretty quickly. Even if the workbench caught fire, it is not near any other combustibles. The workbench is also not situated between me and two exits, one up into the house and the other up to my garage, so escape would be easy if required. Now obviously, if these things explode like a bomb when they go off, I would be in peril sitting right next to it, but it's my understanding from videos I've seen that they do not explode like a bomb, but burst like an overcooked marshmallow and catch fire rapidly. That makes escaping injury a little easier. I'm sure the fumes are not good to breathe when these things burn, which is another reason my first reaction would likely be to hit it with the fire extinguisher. That would hopefully put the fire out and at least blow the fumes away from me initially. After the fire is put out, I have 5 windows and a door that I could open to air the place out, and I could employ some fans to expedite the process. My biggest concerns would be damage to the charger and peripheral equipment, but everything is replaceable; except me!
Sorry for the long post, but, you asked.
~ HelisRule
- Fly safely - Land softly -
       Post #: 3
RE: How do you charge your LiPo batteries? - 11/26/2007 8:15:00 PM
MMatheny
Status: offline
thanx - last thing I need to do is explain to my accountant why my new purchase burned down the house!!!
Mike
(in reply to HelisRule)
       Post #: 4
RE: How do you charge your LiPo batteries? - 11/26/2007 8:30:17 PM
dreimer
Status: offline
Mike,
If I buy a 450 heli in the future, I was thinking of buying one of the LiPo Sacks, just to make it more convienient, and care free with the larger and potentially more dangerous batteries.
You can never be too safe.
       Post #: 5
RE: How do you charge your LiPo batteries? - 11/26/2007 8:50:55 PM
MMatheny
Status: offline
I agree for $20 it's cheap insurance.
Mike
(in reply to dreimer)
       Post #: 6
RE: How do you charge your LiPo batteries? - 11/27/2007 2:43:43 AM
HelisRule
Status: offline
Hey, not a bad idea. I'd forgotten about those.
~ HelisRule
       Post #: 7
RE: How do you charge your LiPo batteries? - 11/27/2007 3:28:44 AM
hobby_man
Status: offline
Dude a 5.00 pyrex pan from the kitchen, with lid.
       Post #: 8
RE: How do you charge your LiPo batteries? - 11/27/2007 5:25:42 PM
HelisRule
Status: offline
Don't think so. Pyrex will withstand the heat of your oven, but I bet a LiPo fire will shatter it in a matter of seconds.
Interesting Pyrex story - My wife had a few Pyrex pie plates in the kitchen cabinet a few years ago, stacked up on the bottom shelf. She came home one day and went into the cabinet to get a pan out, and when she opened the cabinet, small pieces of glass fell out. She found small chunks of glass everywhere, and I mean everywhere, even inside pots on the top shelf. It appeared that one of the Pyrex pie plates had literally exploded, taking at least one other one with it. Never seen anything like it, but would liked to have been at home when it happened, just to hear what it must have sounded like. I still have all the glass pieces (none larger than a pea) and was thinking of calling Pyrex to report it, in case they had a bad run. I don't know how they're made, but I would suspect they are pressed glass and there must have been something wrong with the way this one was pressed that trapped some pressure within the glass. No idea. Hope it never happens again though.
~ HelisRule
(in reply to hobby_man)
       Post #: 9
RE: How do you charge your LiPo batteries? - 11/27/2007 5:54:39 PM
MMatheny
Status: offline
Also, Pyrex can handle high heat as long as it ramps up - a LiPo fire, similar to magnesium, would be too hot too fast!
Mike
       Post #: 10
RE: How do you charge your LiPo batteries? - 11/27/2007 11:51:58 PM
aa2dd
Status: offline
I wonder how a clay flower pot with some sand on the bottom, with a clay cap would stand the intense heat?
Bruce
       Post #: 11
RE: How do you charge your LiPo batteries? - 11/28/2007 10:06:28 PM
dreimer
Status: offline
I'm sure there are many homemade solutions to this, but the LiPo Sack idea is good. Here's a video that shows one in action during some tests.
LiPo Sack
(in reply to aa2dd)
       Post #: 12
RE: How do you charge your LiPo batteries? - 11/29/2007 1:52:28 AM
HelisRule
Status: offline
Yup; gettin' one of those.
~ HelisRule
       Post #: 13
RE: How do you charge your LiPo batteries? - 11/29/2007 4:40:36 PM
MMatheny
Status: offline
Just ordered one from TH - $23.99, compared to $29.99 everywhere else, and I had a $15 credit that helped.
Mike
       Post #: 14
RE: How do you charge your LiPo batteries? - 11/30/2007 4:38:09 AM
soop7667
Status: offline
I've got a Squirrel Cage hooked up to a .5 mAh Micro-Generator. I put my guinea pig in there for about 2 hrs, the balance leads are hooked up to probes on a circuit which in the event of a cell over charging it redirects a burst of energey out of that particular cell and back through the squirrel cage that the guinea pig is
