1/18 HPI rs4 HELP
Tower Hobbies
Logged in as Guest
  Printable Version
OFNA Jammin CRT.5 - ARR
Seller:  jessemxt
Details:   $300.00   |  8/31/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Drifting >> 1/18 HPI rs4 HELP
Page: [1]
Login
1/18 HPI rs4 HELP - 11/26/2007 7:46:25 PM
zsar1
Status: offline
Hi .i was thinking of buying HPI 1/18 micro RS4 ARR. It does not come with a motor and esc. I have a team associated XPS MICRO ESC 29136 and associated SUPER 370 MOTOR.the question is
1. will this work with the HPI 1/18 micro RS4 ARR . if yes, will it be underpowered?
2. will the team associated XPS MICRO ESC 29136 work with HPI Modified Motor 45T Micro RS4.will it match perfectly or not?
3.any other mods recommended for this drifter?
_____________________________
zsar1
       Post #: 1
RE: 1/18 HPI rs4 HELP - 11/26/2007 10:18:01 PM
magnat
Status: offline
Why do you want to go with a Mini ??
Why not go with a 1:10th Scale for Drift which will offer more control and easier to work on..
Traction: What a drag.....
(in reply to zsar1)
       Post #: 2
RE: 1/18 HPI rs4 HELP - 11/27/2007 5:23:53 AM
fl0PPsy
Status: offline
I cant comment on your choice of esc and motor there although I can tell you that to use the HPI Mod'd motor with the XPS micro esc you'll need to change the standard plug that comes pre attached to the HPI RS4 Micro motors.
Other mods or hopups I'd recommend are:
- Lock the rear diff (The drift micro RS4 comes with a little spool diff that you can install in the rear)
- Consider converting the chasis to a Penguine RC Carbon Fibre chasis. (serious improves handling and also increases your electronics mounting options.)
- Get yourself a set of the Micro RS4 drift tires which HPI have released. They are basically the same as the Drift-T's for 1/10 cars and have a perfect grip/slide balance.
Glad to see another mini drifter Mini's can be great for indoor and winter time use because you can rig up a little track almost anywhere in your house. I have a little track marked out in the Kitchen/Dining area of my house and its great being able to get some drift time in any time of day (with airconditioning hehe).
4 x TA03F Pro-2 x TA03R-TA05MS-ProD-Micro RS4 Drift-Sprint 2 Stage D-MR4TC SD CM-TT01 CF Converted-Dark Impact-Frog-Lunchbox
(in reply to magnat)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.219RCU1
