3dsky
WI, USA Status: offline
I had the same problem with my first profile on a 2 stroke. I could lock into a hover all day but could not get it to rotate. I learned to torque roll using a Shock Flyer Extra 330 electric. It had the big diameter prop relative to the size of the plane and had a fast response feel to the motor. Just pulsing the motor would start the plane rotating. I found that the small prop on my OS 46 was not giving me the mass or torque needed to start the rotation. After getting the feel of the sweet spot with the Shock Flyer and getting used to pulsing the throttle (fast blips of power) I was able to do the same thing with the OS 46. I had to use higher nitro fuel and set the low end rather lean to get a fast response to the throttle. I now use a Perry V30 pump to even better success. So watch some videos of other guys using the same engine and get a feel where the sweet spot is to get the plane to torque roll. Some planes will sit a little on their backs and you may have to blip the ailerons with the throttle to start the rotation. The same sweet spot for a solid hover is not always the same for a torque roll. You have a great set up just keep trying, you will get it. I have switched to using a YS 63 4 stroke to get a little more punch. Good luck don’t give up. Sounds like your are doing great on just 15 flights, I think it took over 60 for me to get it.
_____________________________
Skywriter Graphics, SkyitoutRC.com
