StormJunkie -> RE: flyzone diablo (2/16/2008 12:57:51 AM)
Hey Everyone [;)] Have been reading this thread for the past week as I was debating getting a Diablo or not...First a little about me... Really enjoy RC flying, but know very little about it. Been playing with several of the Air Hog type 2 channel planes for the past year or so and wanted to step up in to the slightly larger arena. Anywho, like the replacement parts for the Diablo as well as the potential to upgrade, not to mention it was about the least expensive way to get something larger and with a little more power. So I ended up getting one... I knew that I would break it and have to repair it as well as replace parts to make up for the learning curve, so I was prepared for that going in, and anyone else in a similar situation should understand that the plane will break and likely early on if you have not done any 3 or 4 channel flying. Anyway, got the box and had to make a repair to the radio right off the rip as the little plastic mount for the antenna was broken. So took care of that with some Guerrilla glue and took to building the plane. I took the advice Erik gave and hollowed out some of the nose of the body so I could slide the battery forward. Slid it as far forward as I could and then added two pennies to the top of the battery. The center of gravity was exactly where it was supposed to be. Made sure the rudder and elevator were straight and working, burnt the engine in, and off to try and fly... Got to the field; had a thrower toss the plane, was on the last 180 of a oval and made the turn too sharp, got the nose pointed up, and stalled it during the turn...plane went nose down from about 30 feet up. Crushed the nose back to the battery compartment and broke a wing. Looked pretty rough. Took it home and with a little packing tape and CA glue I got it back together, at least well enough to fly...Back to the field, same result, less fly time. All of this because I am learning to fly. Not poor plane performance. Took it back home repaired it again, and took it out the next day. First flight went great. Flew around awhile, landed and flew some more. Eventually crashed it again, but it will also repair again. So I am basically happy with the plane, I knew what I was getting in to. The plane is very easy to repair, and despite the talk about the rudder being flimsy, the tail is the only section of my plane I have not broken. I like the way it flew with the battery compartment carved forward some, but I would suggest adding some packaging tape to that area to add strength where it was carved out. I would also suggest taping the cockpit/cover on during flight. Mine came off during the first crash, and I think if it had stayed on it would have added some rigidness to the whole battery area. I also suggest adding a strip of tape down the underside of the plane. If the plane goes nose down this should help keep the belly strip and reinforcements in place. The engine mount areas could also use some tape in the thin area where the wing mounts. The wing mounts could also take a little tape around where the through rod goes. I would go ahead and tape these areas if you are pretty sure you are going to crash. If you don't, you will be taping them soon. After adding tape to my plane I removed one penny from the nose. Maybe add a little slice of tape around the engine mount hooks as well as I had one of these break on me. With three good hooks and a little tape my engine pod is staying on. Since I read much of this prior to ordering my plane I also ordered the dual pod, the stunt wings, as well as a brushless motor. I have also already ordered two more bodies, a engine pod, and another wing set. I plane on continuing to repair the currently functional but wrecked plane while I gain confidence. My next step will be to add the brushless motor to the single pod. Then I will try the stunt wings out at some point. Finally at some point I plan on putting the dual pod on with dual batteries. This is where I need help... PLEASE HELP... If I am going to put brushless motors in the Diablo dual pod what size battery should I step up to? Also a couple of general li-po questions...How often should they be charged? Do they have to be drained prior to charging? What kind of fly time should I expect from the Diablo stock setup and would there be a difference if the brushless were installed? Thanks y'all, this thread was a big help in my decision to get one of these planes! [:D] Also if you are looking for some really great real time weather data on the web...no charge, no cookies, no ads... http://www.stormjunkie.com
