Erik St.
bliss, or others who say the plane is slow, I agree it is no Stryker, but it is a "trainer" jet. have you seen the video form flyzone? Does yours fly like that and you're calling that slow or does yours not perform like the one in the flyzone video? I really want to know because if you're calling the one in the video slow, then you just need a higher performance plane. If your's does not fly like the one in the video then I think we can help get the thing to do it. When your's is flying slow, is the nose pointing up? If so, and I cant stress enough, you've got to get the weight way forward, again, I had to carve out an inch of foam to get the battery far enough forward and add a nickle. I also have the pod about .75 inch forward which helps. Before these mods mine flew with the nose up and was SLOW, now mine flys just like the video and it's as fast as anything should be with only two adjacent soccer fileds space. Mine flys just like this, not blistering, but fine for a second plane for me. http://www.youtube.com/watch?v=2tWUqR_4DH8&feature=related
