Erik St. -> RE: flyzone diablo (3/13/2008 3:56:19 AM)
Animal acker, you'll be fine with the 1500mha; I have flown the original 1500, a quality 1650, and cheapo-chinese 2200mHa. All worked fine. Interestingly enough, in an unscientific manner, I have not noticed glitches since the brushless up grade. Mark-my-words: It was the ESC causing trouble! So, with the new BL upgrade and the 30ampESC I have not noticed glitches. but then again I do have horrible vibration at mid throttle. I tried a new rotor and it did not help. My guess is that my Hyperflow unit has been through so much that it is not balanced. I have removed melted palstic a few times after crashes and mis-adventures. I bet that is the cause. Lastly, luckily, the vibration occurs at around 20-35000 RPM, so as long as I'm willing to goose-it to 45,000+ it sounds clean, I just wonder how long the gear wil hold up? Lots of fun, lots of tinkering, that's what it's about, right?
