TF Piper Arrow GE II kit - nose gear
Tower Hobbies
Logged in as Guest
  Printable Version
AeroWorks Yak 54 .90-1.20 QB W/ YS 1.40S and Hitec Digiatal Servo's "ALL - RTF
Seller:  MOTORMAN37
Details:   $1,200.00   |  7/23/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Kit Building >> Kit Manufacturer Direct Support Forum >> TF Piper Arrow GE II kit - nose gear
Page: [1]
Login
TF Piper Arrow GE II kit - nose gear - 11/27/2007 9:57:48 PM
stelios
Status: offline
I recently built the Top Flite Piper Arrow II gold edition kit with Robart pneumatic retracts as recommended.
Although it is marvelous and steady in flight and landings (6,6 kgs) with very little crosswind I am facing problems with take-offs!
Particularly the plane sometime becomes dangerously unstable durring take-off taxing. Among 10 take-offs I faced this problem already 3 times and by luck the last minute I managed to make it airborne before hitting it out of the runway. It was a terrible experience. I have checked everything such as:
- all three gears are alligned and facing straight forward.
- nose gear is alligned with rudder.
- at low speeds the plane rolls straight
- CG is were it should be and a little forward.
- engine is OS FS-120 Surpass E and prop is 16x6
- wheels are Dubro all rubber at the recommended by the manual sizes
- retrats are the recommended by the manual Robart tricycle set
- the plane in flight needed no triming at all
My concern now is towards nose gear end point travel. What is the maximum travel from neutral (zero point) point for the outside of the nose wheel towards right and left?
When ready for take-off should I hold down elevator at the begining or not? what is the best take-off technique?
Thanks for answering my two questions and providing me your advice.
Stelios
       Post #: 1
RE: TF Piper Arrow GE II kit - nose gear - 2/18/2008 9:41:10 PM
Top_Gunn
Status: offline
Re: elevator on take off. I like to hold up elevator until the plane builds up a fair amount of speed. You don't want to actually take off with up elevator, but while taxiing it keeps weight off the nose wheel and helps keep it from digging in.
Can't help with your other questions--still working on my Arrow II.
(in reply to stelios)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
