RE: Hybrid Edge
Tower Hobbies
Logged in as Guest
  Printable Version
50 Size 3D Profile - RTF
Seller:  DAVIS300
Details:   $275.00   |  11/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP - Ohio Model Products Support Forum >> RE: Hybrid Edge
Page: <<   < prev  1 2 3 4 5 6 7 8 9 [10]
Login
RE: Hybrid Edge - 4/16/2008 1:39:53 PM
AFSalmon
Status: offline
That sheet is 100% correct and what I was trying to explain with relationship to the geometry. Both ends must match and rarely do folks cross the cables on giant scale planes. You get rubbing and other problems like messed up geometry due to the offset deviations. Example C is probably the more common these days due to the large and thick rudders. Having the horns offset behind the hinge line makes installing easier but of course you need a matching offset servo horn. Thanks for posting that sheet!
_____________________________
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes, Team OMP Captain
(in reply to tiktock)
       Post #: 226
RE: Hybrid Edge - 4/16/2008 4:33:41 PM
tiktock
Status: offline
i thought i had to cross the cables? on my normal fuse i don't but with the hybrid if i don't cross them, then i would have to make a slit along the hole side of the fuse..... has anyone done a straight pull pull setup on the hybrid?
< Message edited by tiktock -- 4/16/2008 4:34:43 PM >
(in reply to AFSalmon)
       Post #: 227
RE: Hybrid Edge - 4/18/2008 3:44:44 PM
Trisquire
Status: offline
I haven't walked through this whole thread. Just curious. Is the Hybrid Edge legal for IMAC competition? I know it's sort of a profile, but is it true to scale enough?
Tom
< Message edited by Trisquire -- 4/18/2008 3:46:05 PM >
       Post #: 228
RE: Hybrid Edge - 4/18/2008 8:19:49 PM
alpapilot
Status: offline
quote:
ORIGINAL: Trisquire
Tom
I think you need a pilot and an instrument panel for IMAC. Unless you fabricated a clear canopy that rules it out. However, I do wonder if you where to put a picture of a pilot on the side if that would count .
(in reply to Trisquire)
       Post #: 229
RE: Hybrid Edge - 4/19/2008 3:31:34 AM
Constrictor
Status: offline
I want one
OMP Distributor
(in reply to alpapilot)
       Post #: 230
RE: Hybrid Edge - 4/19/2008 4:18:51 AM
Crash90
Status: offline
Constrictor. You would love it.
Tiktock. I have my cables crossed. My pivot point is right on the hinge line and my servo arm is slightly offset. My gemetry is perfect. I have the same tension on my cables all the way through the motion. I mounted one cable to the top of the servo arm and the other to the bottom. I am using a SWB servo arm which is about 1/4" thick. Tthis keeps my cables far enough apart that I don't have any problems with cables rubbing.
< Message edited by Crash90 -- 4/19/2008 4:23:23 AM >
(in reply to Constrictor)
       Post #: 231
RE: Hybrid Edge - 4/19/2008 12:14:17 PM
Trisquire
Status: offline
quote:
ORIGINAL: alpapilot
That shouldn't be too hard to fabricate. I'm surprised more people don't select the Hybrid Edge as a 50cc IMAC choice. Sure, you have to build it, but it's a lot cheaper than the alternatives. Seems to have a better wing loading too.
Tom
       Post #: 232
RE: Hybrid Edge - 4/19/2008 1:52:39 PM
alpapilot
Status: offline
quote:
ORIGINAL: Trisquire
Tom
That is probably the biggest understatement of the year .
       Post #: 233
RE: Hybrid Edge - 4/21/2008 6:52:27 PM
AFSalmon
Status: offline
To fly IMAC though you have to be a scale plane. You could fly the Hybrid in Novice class though as this rule does not apply. In the Sportsman and up class though it has to be a scale plane. I was surprised how well the Hybrid does fly pretty good IMAC circuits.
       Post #: 234
RE: Hybrid Edge - 4/22/2008 6:09:17 PM
outssider
Status: offline
Has anyone been able to get the hybrid to do an inverted flat spin???... I have used up all my tricks and still can't get even close. Hybrid just starts flipping over on itself. if you try using less elevator, the plane just goes willy-nilly all over the place. I have got a decent up-right flat spin although it's not locked in as well as i'd like. I have a feeling that the extreme taper of the wing is not condusive to flat-spins.
       Post #: 235
RE: Hybrid Edge - 4/22/2008 6:29:42 PM
rcplanenut
Status: offline
Yes, I can do inverted flat spins all day long with my hybrid. start with a blender into the flatspin. It will also do upright flat spins
(in reply to outssider)
       Post #: 236
RE: Hybrid Edge - 4/22/2008 8:50:34 PM
Trisquire
Status: offline
quote:
ORIGINAL: AFSalmon
Well, you could probably use the wing and tail surfaces verbatim. The fuselage would require some modification to make it scale-like.
Tom
       Post #: 237
RE: Hybrid Edge - 4/23/2008 2:22:44 AM
alpapilot
Status: offline
quote:
ORIGINAL: rcplanenut
Same with mine. Blenders are nice and slowwww.
(in reply to rcplanenut)
       Post #: 238
RE: Hybrid Edge - 10/1/2008 12:19:21 AM
3D_Junkie
Status: offline
quote:
ORIGINAL: alpapilot
Hee Yah, It's DONE! (except for the number "55" on the right wing. I'll do that tomorrow.)
DA-50 w/ Slimline pitts
HS-5595's on ailerons
HS-5645's on rudder and elevator
Fromeco Wolverine switch
Dual A123 two cell packs on RX
Common Sense RC 2000mAh 2s lipo on ignition
42 Percent Products Opti ignition kill switch
AUW = 16.5 pounds! Kick A$$!
alpa,
How many rolls of covering did you use for that scheme?
< Message edited by 3D_Junkie -- 10/6/2008 2:05:30 PM >
       Post #: 239
RE: Hybrid Edge - 10/3/2008 11:05:48 PM
